Very odd breakdown
So I walked, got my tools, and asked a neighbor to help me out, tow me home if necessary. We did the usual checks, fuel, good, spark, nothing, voltage at the coil, 3V, not so great. With the sun setting, and my friend nervous about towing her, we decided to call AAA. The flatbed was there in about an hour and got her home.
Today I once again went through the usual checks, still 3V at the coil, but now I have spark. She fired right up.
Not satisfied, I pulled the ignition switch and checked for any faults, excess resistance, etc. I checked all the grounds, every connection (ok both connections) and everything checks out. I drove around my neighborhood for 20 minutes, and left her idle in the driveway for another 20 minutes. No problems.
I’m stumped, and nervous about taking her more than a few blocks away, I don’t want to get stuck.
Thoughts?
What happens if you remove both the (+) and (-) from the coil, and take a Voltage measurement at those wires? (Be sure to rotate the engine so the points are closed and have the ignition in the RUN position). You should have battery voltage (A nominal 6V)
Disconnect the coil (-) terminal, and measure the voltage from that wire to the (+) terminal of the battery with ignition in RUN. It should be 6V. If not, check your wiring from the coil to the ignition switch.
Take a 6 volt test light bulb and connect (assuming your ignition is + ground) from the + side of the coil to a good ground with the + wire STILL connected to the distributor. It should flash with the engine turning over. If not, you have a bad module.
There should be some thermal insulating paste I believe under those modules to help dissipate the heat. Is there?
Also in talking to other folks about those. They don't like low battery voltage. Especially if it happens to be a Pertronix Ignitor II module.
EDIT:
Just another quick tought, Is you coil a Pertronix also? Just asking as too low of resistance coil will cause those Pertronix modules to run hot and could
eventually damage them.
EDIT:
Yes, it’s a pertronix coil as well, and yes, these things hate low voltage. I had trouble with the stock generator, it simply didn’t supply enough current to keep the battery up to full charge. it’d backfire, ping, and do all kinds of nasty stuff. I replaced the generator with a powergen alternator and it’s been great.
Im ordering another Ignitor II before even running the test,
Since I’ve eliminated everything I can, I’m going to replace the module. I ordered it from pertronix and it should be here in a few days,
Thx to everyone who replied, especially hooler.
The test as hooler describes, bypasses the coil feed and the coil leaving those as potential places for issues to remain.
I'm not saying that your pertronix isn't at fault as they are are known for failing like this, but it is smart to cover all your bases so you don't somehow damage your new unit (or could have saved you some dollars before jumping the gun).
I know you already ordered it, but it was an Ignitor ll that I had problems with too.And it sounds like very similar symptoms I had. In fact I nursed my truck home for 70 miles with the same issues going on. The engine would die, sometimes the ignition came back and the engine would run again, being spun over by the transmission at 55 mph, other times it wouldn't start, and I would have to let it sit for 20 to 30 mins. Finally got it back home and it died again pulling into my driveway and it would not run again with that particular Ignitor II module.
Turns out the Ignitor II has a reputation of dying this way. I spoke with someone at Pertronix, who advised me to upgrade to the Ignitor III, but he told me I could keep using the II coil. That's exactly what I did and that was some 8 years ago. I have had no problems since. The Ignitor II coil has a higher resistance and doesnt make the III module work as hard so you have a safety margin built in for the module in that set up.
So my recommendation is try to upgrade to the III module if you can. (If it's available for your truck that is).
I actually purchased from the Pertronix store on Amazon so free returns. If they make the Ignitor 3 I’ll get that. When I bought the module, they said this was the only 6v + ground they manufactured, but that was over 2 years ago.
FYI, I don’t have a 6v test light, so I hooked up my meter and rotated the engine by hand. I could see it go from 0 to 6v easily. My best guess is that it will work fine until it heats up.
Sorry Bob, I thought you were already using a Pertronix 2. My bad. And I doubt they make a Pertronix 3 for a 6v positive ground. But it's been several years since I shopped for one. The Pertronix 1 has a good reputation. As far as I know it's just a hall effect switch. Do you know if your Ignition was accidentally left on with the engine not running? Like another family member moving the truck, accidentally killing the engine, and walking away from it without shutting off the key? I could see something like that damaging that module if the engine happened to stop at a place where the points were closed and the key left on. One thing about the Pertronix 2 and 3, it will time out and automatically open the circuit from the coil if the key is left on and the engine not running thus saving itself.
My suspicion is that without a good solid physical contact to the dizzy and without thermal paste, it simply overheated and shut down. I’m not comfortable driving any distance to test that theory, but I’ve driven around my neighborhood a few times without any trouble. Once I get the new module I’ll be braver.
Thx for all the help, this is the best forum in the world.
