Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Would You Run This Winch?
Old Aug 12, 2024 | 09:29 AM
sum_weirdo's Avatar
sum_weirdo
I'm not experienced with winches, and this probably isn't a high quality one either. It came as part of a Power Fist crane from Princess Auto.
I did my best to thread the end of the cable through the holes, with a "binding loop" supposedly holding it in place. But the cable is stiff and unyielding. So the loop never ends up that tight. And it tends to get looser as the cable is wound onto the drum, forcing the inner part of the loop out of position until the tip is hardly bound at all. I think it actually got worse after taking this pic.
The cable still held my 70 lb test load securely. But I'm going to lift a 300 lb short block soon, and I don't want any crap-ups.
Old Aug 12, 2024 | 03:22 PM
tjc transport's Avatar
tjc transport
i ain't rite
i do not rely on knots. i use a small cable clamp to firmly secure the end of the cable to the loop.
i also bo not leave a cut end. i either cut the cable with an oxy acetelene torch, or weld the cable end to have a small bulb on it.
Old Aug 12, 2024 | 04:27 PM
RLXXI's Avatar
RLXXI
No I wouldn't run a hand cranked winch. Well,.... except for a boat that is. If it's on my truck, it's juiced via the battery.
Old Aug 15, 2024 | 01:38 PM
PupnDuck's Avatar
PupnDuck
Its also good practice to always leave one complete layer of cable wrapped around the drum.
silverhawksurfer
Feb 6, 2024 11:24 AM
traveldawg
All Things Towing
Dec 14, 2022 05:31 AM
HRTKD
All Things Towing
15
Sep 11, 2022 10:21 AM
Dcurre1
Nov 25, 2020 09:55 AM
natewoz
Offroad & 4x4
Apr 27, 2005 08:26 AM
