Sponsored by: Real Truck
Steering Issue
Old Aug 11, 2024 | 04:09 PM
ldruth61's Avatar
ldruth61
Trailering
Steering Issue
My 1999 f250 super duty steer seems slow to return while driving when I am trying to keep it straight on the road. It almost feels like a delayed response and then I overcompensate. I tried tightening up the steering box and while it takes up any play in the wheel, it does not stop the slow return and actually feels too tight/jerky when I go to control it. Because of that I loosened it back up some. While driving, if I turn the wheel back and forth really fast it feels sluggish to return and the whole front end of the truck kind of wabbles back and forth. I am handy and work on my truck myself, but I really don't know much about suspensions.
Any suggestions on what could be causing this to happen?
Thanks
Dean
Old Aug 11, 2024 | 08:36 PM
Eman85's Avatar
Eman85
Check all of the front steering and suspension, especially ball joints.
Old Aug 11, 2024 | 09:09 PM
ldruth61's Avatar
ldruth61
Trailering
I understand I should check my front steering and suspension and ball joints. I just don't know what to look for as to what would be the issue.
Dean
Old Aug 11, 2024 | 09:54 PM
Eman85's Avatar
Eman85
Do a google or Youtube search and see how to check suspension.
Old Aug 11, 2024 | 10:53 PM
ldruth61's Avatar
ldruth61
Trailering
yes of course. But I am hoping someone has the same issue and may have the exact fix. Cheers
Old Aug 12, 2024 | 06:59 AM
projectSHO89's Avatar
projectSHO89
Has anyone been screwing with the adjustment on the steering gear? If so, it's over tightened now, probable due to a gear that was worn out in the first place.
Old Aug 13, 2024 | 10:19 AM
bajaphile's Avatar
bajaphile
Quick check for steering play, get a helper to get in the truck, turn on engine and move the wheel side to side slightly. While they are doing that, look at all the end links for any play. Watch input shaft movement vs output on steering box/gear. Check for upper and lower ball joint slack while turning wheels as well. There should be 0. Another way to check ball joints is to jack up and support front axle, and grab wheel at 12 and 6 o'clock and check for vertical play. You can also check by trying to turn each wheel side to side and look for any play in steering linkage (end links).
Old Aug 13, 2024 | 11:27 AM
Eman85's Avatar
Eman85
If you want to check ball joints jack one side at the axle and get the tire just a couple of inches off of the ground. Put a block of wood just outside the tire and use a pry bar as a lver on the block of wood and lift the tire vertically while someone observes the ball joints.
Old Aug 14, 2024 | 09:17 PM
irydasteelhorse's Avatar
irydasteelhorse
double check the pitman arm nut, use about a 4 ft cheater bar to tighten it down.
SNYDER68
Feb 15, 2023 07:20 AM
SRock123
Apr 8, 2021 06:06 PM
longt
Nov 20, 2017 05:31 PM
Badger F350
Oct 7, 2009 02:50 PM
jtolo3
Oct 17, 2003 08:00 PM
