Will it handle it?
Old Nov 28, 2003 | 06:21 PM
red2001crewcab's Avatar
red2001crewcab
Will it handle it?
I just bought a Coachmen 5th wheel camper I think the empty wieght is around 7500lbs. I have a 2001 f-250 4x4 crewcab with a v-10. I hope this will not be a strain on the truck. I have not had the truck but a month but it seems to enough torque and horsepower to handle it.
Old Nov 28, 2003 | 06:24 PM
black98f150's Avatar
black98f150
no problems at all,my uncle has the same set-up and tows all the damn time.......
Old Nov 29, 2003 | 06:24 AM
red2001crewcab
Thanks for the info.
Old Nov 29, 2003 | 11:24 AM
MisterCMK's Avatar
MisterCMK
What is the GVWR on the truck? You can NOT, I repeat can NOT exeed that limit. That is the combined weight of your truck, people in your truck, fuel, luggage, the trailer, stuff in the trailer, and anything else attached to your rig. If you exceed that number, you are pushing the limits of the truck, and asking for disaster.
Old Nov 29, 2003 | 06:28 PM
dtpatt2's Avatar
dtpatt2
You will not have a problem with GVWR. Your truck won't have a problem, that's a pretty average 5er.
Old Nov 30, 2003 | 07:09 PM
red2001crewcab
Thanks again for the info. I will be going to pick my truck and camper tomorrow or Tuesday. I will have about a 60 mile drive back home that should let me know how the truck will do. Thanks again.
Old Dec 1, 2003 | 12:02 AM
Shake-N-Bake's Avatar
Shake-N-Bake
You shouldn't be close to your GCVWR, might even have 4 or 5 k to spare. You might have an issue with bed rail clearance though. I had to have my axles flipped on my fifth wheel in order to clear the bed of my 4x4 F250. Which actually wasn't a problem for me because my trailer is a toy hauler for dirt bikes and quads....so I need extra gound clearance when I drive off road anyway. Take a look after everything is hooked up and make sure you have enough clearance between your truck bed and the overhand of the fifth wheel. Also take a look on level ground and see if the trailer is sitting level as well. You can play with your pin box height, but sometimes that puts too much weight on the rear axles and could cause a dangerous blowout.
Old Dec 1, 2003 | 08:12 AM
CLPF350's Avatar
CLPF350
Red 2001 Crewcab:
No one has mentioned the clearance needed between the fiver overhang and the truck bed rails. 6" is considered by many to be a minimum. I run 8" because of some unique situations getting into and out of my driveway. 4" clearance is almost guaranteed to create a problem somewhere down the line.
CLPF350
Old Dec 1, 2003 | 06:54 PM
red2001crewcab
The guys at the dealership told me I would have to take my toolbox off. They said it could get into the camper when making a turn on a hill. I really do appreciate all the feedback I have been getting.
Old Dec 1, 2003 | 09:55 PM
sportscar's Avatar
sportscar
Just pulled out my trusty handy 2001 Ford Towing Guide. Your truck max 5th whell trailer ratings:
Auto: 3.73 rear 10,400 lbs, 4.30 rear 13,400
Man : 3.73 rear 10,000 lbs, 4.30 rear 13,500
PS I double checked these numbers!?
Old Dec 2, 2003 | 09:06 AM
CLPF350's Avatar
CLPF350
Just to clarify vocabulary:
camper: usually refers to a slide in unit
Fifth wheel, fiver, etc. refers to units with hitch mounted in the bed and more or less centered over the axle.
trailer, pull trailer, etc refers to trailer using a frame mounted rear hitch or less frequently a bumper mounted hitch.
No disrespect intended.
CLPF350
