Reverse Lights Wiring
Old Aug 11, 2024 | 09:26 AM
UnashamedMTBigBlock's Avatar
UnashamedMTBigBlock
I'm installing an aftermarket transmission controller from US Shift, a Quick-4 unit, to run my E4OD. Their kit includes a new harness with a few wires that I need to connect to existing circuits, in order to maintian factory functionality. Right now, I need to tie the reverse light signal from my range sensor to the truck's reverse lights, so those will remain functional.
First off, is there a fuse in one of the panels that protects the circuits for the reverse lights, that I should tie this reverse light signal into, or will I have to tie it directly to a wire, in order to send 12v power to the taillights from the range sensor, adding a fuse inline somewhere?
If I do have to tie directly into a wire, what colors should I be looking for?
Old Aug 11, 2024 | 03:23 PM
Prototypemech's Avatar
Prototypemech
Fuse E under the hood powers the reverse light circuit.
Old Aug 11, 2024 | 03:55 PM
UnashamedMTBigBlock
Which fuse is fuse E? My fuse box has positions labeled with numbers, not letters.
Old Aug 11, 2024 | 04:20 PM
McLeod's Avatar
McLeod
https://www.ford-trucks.com/forums/1...l#post15794859
Old Aug 11, 2024 | 05:07 PM
Prototypemech
You didn't mention what model or year truck you're working on.
Old Aug 11, 2024 | 05:11 PM
UnashamedMTBigBlock
You're 100% correct, that's on me, my apologies. It's a 1995 F350, CCLB, 4WD, with the 460/E4OD engine/transmission combo.
Old Aug 11, 2024 | 05:30 PM
rla2005's Avatar
rla2005
Engine compartment fuse panel should be labeled in letters.
1995 F-Series gas engine power distribution diagram:
Corcorannt
Sep 24, 2022 06:55 AM
drivefaster35
Feb 24, 2022 08:14 PM
corksil
May 12, 2020 08:39 AM
beefey
Nov 25, 2017 05:06 AM
F350-6
17
Jun 28, 2015 09:18 AM
