Wait until the Federales get ahold of this one and legislate... All of those PC's on recall, and if you are a registered owner of a device; provide proof that the offending marks were removed. If you can't, then you get a 20 yr mandatory jail sentence.
I wanted to reply to this, but everything I tried to write sounded bad, so I gave up.
My thoughts are tending toward racist because of the stupidity of some. I wish that we could all say enough, and get on together -life is too precious to ruin with all this PC crap.. (oh dear, theo said a bad word.)
That has got to be the most rediculous thing I have ever heard of! Where will it stop? Will we have to refer to the "Master" switch in a 3-way switch and the "Primary" and the "slave" switch as "secondary?" What a crock!
But, here's the kicker. You can't use the Primary/Secondary/Tertiary terms, they're taken. In a rendundant processing environment (more than 1 system processing the same information for the sake of emergency readiness and error tracking), the system that is currently communcating with the network is the Primary, whereas the Secondary typically either recieves the data from the primary system, or off of the network without responding. This is not a Master/Slave relationship, since the Primary system has no control over the Secondary..
Gee, that was excessive, now, wasn't it. Can ya tell what I do for a living?
OMG! This has got to be the most frivolous and utterly disgusting lawsuit! When will people get over this the slave era was over almost two hundred years ago! GIVE ME A BREAK!
