Wiring validation #2 - Key/ignition
Old Aug 10, 2024 | 02:31 PM
w951wxj's Avatar
w951wxj
Up to wiring the key/ignition switch with the new wiring kit - of course things are labeled but seldom the same colors so just working through the diagrams and need some validation help - at this point the truck is a shell, engine being built - trying to get some wires in so its not to the point that I can really test much per se. Here are the details:
1973 F100 custom 302 2wd LB - as basic as it comes
Ign switch
  • 21 Yellow - Power - goes to battery side of starter relay
  • 32 - Red/blue - Neutral Safety switch
  • 16 - Red Green - Coil
  • 297 Black/Green - Instrument cluster
  • 977 Purple - Accessories
Is that correct? looking at all the diagrams for a 74 F100 on Fordification (since no 73, I suspect its still all valid) these are what I see with the switch wires...Anyone know anything different, do I have something switched?
Old Aug 10, 2024 | 05:07 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Auto or manual trans? Check this out. https://autokrafters.com/wiring-diag...-series-truck/
1974 Auto transmission NSS is involved
1974 manual transmission NSS is by passed
Old Aug 10, 2024 | 09:43 PM
w951wxj's Avatar
w951wxj
Auto - C4, sorry forgot that detail
Old Aug 10, 2024 | 10:21 PM
w951wxj's Avatar
w951wxj
The black with green stripe is giving me the most stress - its either listed in the diagrams and runs all over or its not listed as Black with green stripe but something else - In the fordinfication wiring diagrams it should be 297 coming off the ignition switch. It really comes down to the black/green and the purple - one is the accessories and the other is the instrument cluster...I keep waffliing on which is which
814x4390
Large Truck
26
Jun 5, 2024 02:35 PM
gordy71
Jan 27, 2019 12:00 PM
1966f250
Dec 5, 2018 09:05 AM
scottlathrop
Nov 24, 2013 07:54 AM
soco
Electrical Systems/Wiring
Aug 5, 2012 07:04 AM
