Sponsored by: Kumho
Binary Brakes
Old Aug 9, 2024 | 07:34 PM
Glebis's Avatar
Glebis
7th Gear
Question Binary Brakes
1994 F350 V8 Gas
When applying the brakes the wheels will lock after the brake pedal moves a small amount, as can be seen in the video with rear lifted off of the ground. I replaced the master cylinder, the booster (observing clearance between master and booster rod) and ABS sensor on the rear differential (no sensors on front tires). Any suggestions as to next steps? Is this indicative of a bad ABS controller?
Thanks in advance,
glebis
File Type: mov
Old Aug 9, 2024 | 08:53 PM
xlt4wd90's Avatar
xlt4wd90
Did this start happening after you changed the MC?
This happened to me a long time ago when I did that, and dropped the little rubber cap that sat between the pushrod going into the MC and the vacuum diaphragm. That little cap acts as a cushion between the diaphragm and the pushrod, and losing it changes the distance between the two, so it throws off the power assist curve. On my rod, there is a threaded length adjuster, and setting it helped, but without the rubber cap, the boost activation was still abrupt.
In my case, I dropped the cap into the vacuum housing; it was way too easy to do if you're not careful pulling out the pushrod. It required pulling the booster off the firewall to shake it out. I could never figure out where to buy one of those things.
I'm not sure if newer brake boosters and MC still use the same arrangement.
Old Aug 10, 2024 | 08:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
that is normal for a vehicle lifted off the ground. i can lock up all 4 wheels with one finger push on the pedal. once down on the ground and go for a drive you should see no problems with the brakes.
Old Aug 10, 2024 | 09:36 AM
Glebis's Avatar
Glebis
7th Gear
Thanks for the response. The truck was doing this before changing the MC and booster, which I did at the same time as the ABS sensor, there was no cap, and I used a push-rod pin adjustment tool that measures distance from MC engagement point to push-rod position to ensure proper clearance.
Old Aug 10, 2024 | 09:40 AM
Glebis's Avatar
Glebis
7th Gear
Thank you for your response, the truck behaves the same when on the ground, if I push the brakes more than a little bit they go into a hard lock. After replacing the MC, booster, and ABS sensor it seems that I can push the pedal further farther without locking up. Last night it occurred to me that I should remove the fuse to the ABS controller to eliminate that as a potential cause, I will do so today.
reddyj
2004 - 2008 F150
15
Apr 13, 2020 01:04 PM
barkfarm
Nov 24, 2015 06:39 PM
Ben24
Oct 5, 2013 11:46 AM
jsims813
Apr 8, 2012 09:51 AM
roadwolf
Mar 9, 2004 01:11 AM
