ECT 192-201 EOT 220-240
Old Aug 8, 2024 | 11:32 PM
dmaximus's Avatar
dmaximus
coolant sprayed on windshield
checked fan clutch found wired cut by fan
flushed coolant system
changed fan clutch , water pump, thermostat, radiator with parts from SANDERSON FORD
ECT runs very cool 188-201 in daily 110 degrees in phoenix
EOT reaches 220-240-258 in 110 degree days
bought BULLETPROOF DIESEL OIL COOLER and square EGR COOLER combo installing in 2 days
Old Aug 9, 2024 | 05:13 AM
tfunk88's Avatar
tfunk88
Will be interested in seeing what oil temps are afterwards 👍
Old Aug 9, 2024 | 07:35 AM
joe blow's Avatar
joe blow
This is by far the best thing you will ever do for your truck....HANDS DOWN!!
IMO keep it going and ditch that fan, go with the Hayden 7.3 fan and be done with the visctronic all together. That thing gave me nothing but problems and in your type of heat, I'd do it again in a heartbeat.
Just an opinion
Old Aug 9, 2024 | 08:03 AM
Byrd.Dog's Avatar
Byrd.Dog
Just for clarity - you purchased the stock - style oil cooler, not the full conversion?
Old Aug 10, 2024 | 06:31 AM
dmaximus's Avatar
dmaximus
i purchased ford oil cooler and BPD egr cooler with all the gaskets i will need in the process intake manifold etc.
BPD wanted $2000 to put it in
Old Aug 11, 2024 | 12:51 AM
dmaximus's Avatar
dmaximus
what is that little oval screen for below the oil cooler mine was completely blown out
i am in the middle of BPD oil cooler and egr cooler replacement its quite a journey accessing that thing
when i got the cooler out i tried to blow through the coolant side of it
it had the flow of a single COCKTAIL STRAW !!!
Old Aug 11, 2024 | 02:52 AM
dmaximus's Avatar
dmaximus
that's a great suggestion thank you
I'm not a big fan of electronic clutch
just happen to have a 99 f-350 with a 7.3 Hayden clutch I'm not using i need to sell that truck
i keep taking parts off it
Old Aug 11, 2024 | 02:55 AM
Hartwig's Avatar
Hartwig
screen from IPRResearch works.
Old Aug 11, 2024 | 05:50 AM
tfunk88's Avatar
tfunk88
The screen is to keep stuff from getting to your high pressure oil pump
To be clear, it’s a Ford oil cooler purchased from BPD, not their external air cooled oil cooler kit, correct?
Old Aug 11, 2024 | 06:18 AM
dmaximus's Avatar
dmaximus
yes a ford oil cooler you are correct
Old Aug 12, 2024 | 03:15 PM
Kemicalburns's Avatar
Kemicalburns
any updates?
Old Aug 12, 2024 | 10:53 PM
dmaximus's Avatar
dmaximus
so far unbelievable temps only drove it 30 miles delta 2-5 degrees i will give a better update after i go to mountains this week
Old Aug 13, 2024 | 08:06 PM
dmaximus's Avatar
dmaximus
disaster has stricken or has it ?
during the big oil cooler egr cooler installation this last weekend something dropped in to #8 intake port i dont know who or when but it happened
when i started it we heard a very strange noise
and i got a code for #8 cylinder not contributing properly
so the next morning i drove it to work 30 miles and the deltas were awesome...
took it to a nearby shop to have the #8 diagnosed
they said it was only 300 compression on that cylinder so im guessing something went down the port and bent the valve
anyways i need a shop to fix it anybody know any good shops?
Old Aug 13, 2024 | 08:14 PM
joe blow's Avatar
joe blow
Oh no that is terrible my friend.
Old Aug 13, 2024 | 08:15 PM
tfunk88's Avatar
tfunk88
Oh man 😳
I hope somehow it turns out to be minor…but that is A LOT of work to fix 😬
Where are you located to recommend shops?
