Need a connector/pigtail
Old Aug 8, 2024 | 08:10 PM
Eman85's Avatar
Eman85
Doing a little checking under the hood and found one of my connectors doesn't lock on the sensor. The sensor in on the back side of the HPOP so I guess it's the injector pressure sensor, it's a 2 wire connector. Anyone have a source for a connector or pigtail?
I noticed the pigtail on the sensor that screws into the drivers side head has been replaced, is that fuel pressure sensor? They did a poor job with scotchlocks and tape so I fixed all of that with proper connectors and shrink tube.
Old Aug 8, 2024 | 08:21 PM
John in OkieLand's Avatar
John in OkieLand
it is the same connector as on a lot of the injectors, per an online source I watch.
so, if you saved an old Injector harness, keep the connectors.
goto
https://www.riffraffdiesel.com
and in the Search box, just type CONNECTOR and get the one you need.
Old Aug 8, 2024 | 09:50 PM
Eman85's Avatar
Eman85
The thing I needed was what sensor it is. I figured it out it's the oil temperature sensor that has the bad connector.
Old Aug 8, 2024 | 10:40 PM
Kwikkordead's Avatar
Kwikkordead
Injection pressure sensor is on the left cylinder head. Without going out and looking, IIRC, the only plug on the rear of the HPOP is the pressure control solinoid. (Forget the acronym right now).
Old Aug 8, 2024 | 11:02 PM
Eman85's Avatar
Eman85
https://www.ford-trucks.com/forums/1...pr-sensor.html
Here's a pic EOT is the sensor I'm needing the connector for
Old Aug 8, 2024 | 11:19 PM
Socket's Avatar
Socket
Heres the ford part
https://www.riffraffdiesel.com/engin...eot-ect-94-03/
I’ll try and see if I can track down a connector tomorrow in the computer through another source. Been doing it a lot lately for another project I have.
Zwalters
Feb 3, 2016 07:26 PM
WB4IUY
Escape & Escape Hybrid
Nov 26, 2014 04:35 PM
MONAVIERONJON
Jun 17, 2013 08:06 PM
iduger
Mar 18, 2012 12:38 PM
Fordy3622
Jan 13, 2007 08:20 AM
