Weird miss fire problem
Old Aug 6, 2024 | 06:40 PM
William H.'s Avatar
William H.
3rd Gear
I have a 92 f150 with 4.9 and 5 speed and she is a great running rig. I do 100 miles a day in her but, she's come up with an issue I can't figure out and I don't want to drive it missing this bad. It's only missing on cylinder 3. No matter what it will not hit on that cylinder. I've done the normal, check plugs, cap and rotor, wires, injectors, everything seems to check out. There is no weird residue on the plug, cylinder looks great on inside by borescope, but no fuel residue on plug. Pulled the injectors and put the number 3 in the number 1 cylinder and the miss did not move. All sensors are brand new as i decided to replace them when I began to drive it farther every day. I'm at a loss. Seems as if the injector is not getting fire. I think I may need to get into the harness and look at the wiring, something just seems strange to me. Truck was running perfectly good one day, the next it has this horrible miss. Any advice or tips is greatly appreciated.
Old Aug 6, 2024 | 07:48 PM
MountainManRobb's Avatar
MountainManRobb
Have you verified all wiring is in good condition? Do you have a noid light to check for signal at the injector?
Old Aug 7, 2024 | 09:27 AM
Junktownbill99's Avatar
Junktownbill99
Compression test.
erpshouse
2004 - 2008 F150
Jan 18, 2011 06:47 PM
adamwg05
Feb 6, 2010 04:27 PM
scottb97
1997 - 2003 F150
Sep 26, 2006 02:04 PM
lost_in_space
16
Mar 5, 2005 05:03 PM
Bigjond27
Oct 27, 2004 04:09 PM
