8.8 to 9" Swap
That sensor is not just an ABS sensor, it controls your speed input, which controls cruise, speedo, odometer, shift points, etc etc. The 9" is about the same as the 8.8, there are pros and cons to both and you will not gain anything by swaping to the 9" if your doing it for strength. The 8.8s are a dime a dozen, easy to get if yours is damaged.
The 9" is comparable in strength to a Dana60. Some parts of the 9" are even stronger than the same parts in a D60, so yes..you will gain strength. Stronger axle shafts, full float kit, and a full axle truss will make the 9" unbreakable with more clearance than a D60.
As for the speedsensor, i'm still trying to figure out the easiest way.
There is another way, and it's very simple to do but requires a little math and a little fabrication. There is a place that sells slip-yoke eliminators for the BW13-56 tcase, with the purchase of that and making up a small sproket (like what is found in the 8.8) with the corrct amount of teeth, you can mount a speed sensor righ above it.
