Noob egr question
Looking at the TB’s, I noticed there was a difference there as well. The jasper intake has two vacuum ports coming from the side of the throttle body where the original TB does not. Is this a f250 thing? Which one should I put on? Does it matter?
As I have no cat, I’m going to run the air pump stuff off the Jasper engine. Close up the tube from the exhaust. I’ll update for anyone in the future lol
As for the emissions, here in Colorado they don't check for emissions equipment, just the sniffer test. Also they check the gas caps (affects emissions somehow)
Jasper TB with two vacuum lines (don’t know what for)
OG TB with no vacuum ports
Jasper exhaust manifold
OG exhaust manifold, pretty similar 🤷♂️
Those lines are EVAP system lines. They carry fuel vapors from the fuel tanks, to the throttle body (Green dots), by way of the charcoal canister, that's in the area below the battery.
The blue dots are the Canister Purge Solenoid. That solenoid opens when the computer grounds it, and let's fuel vapors through. The difference in the EVAP lines configuration, probably isn't a big deal.
I just wasn't sure that the center to center measurement of the exhaust Y pipe, where it flanges into the exhaust manifolds was the same, between the two engines, but I don't have specific reason to think they're different. Might be worth measuring.
Progress has been made
Engine is in, the exhaust fits up (just need to use the pry bar a little to make the flanges lines up)
I do have a question, there is a difference in vaccum lines.
there seems to be two sets of vaccum lines that go to the canister. Not sure what to do there. I will attach some vac diagrams to see if y’all can help me out where to route or just cap them.
I’m trying to get it all together and running this weekend
Extra vac lines from f250 air pump system
F250 vaccum diagram
F150 vacuum diagram
Some direction on what to do here and routing would be greatly appreciated!
I don’t see any other major difference in the equipment of this engine, but I’ll update if I do.
Take a look there.
Also, I believe the white vacuum line is the one that operates the vac valve at top of heater box near hood hinge
