Alternator issues
Old Aug 4, 2024 | 03:45 PM
Marktheidiguy's Avatar
Marktheidiguy
8th Gear
Alternator issues
Two new alternators neither will output power.
Fuses are good. Fusable link is good and the block is grounded .
I have no idea why it will not put out f
More than .04 volts from the stud. I'm completely baffled. Could I have bought 2 bad alternators? Idk I don't think so.
Motors a 92 non turbo 7.3
Chassis is a 94 f350 witch did have a turbo in it I used the turbo wiring harness when I put this non turbo in this truck so I could mount the glow plug controller on the valve cover instead of the back of the engine. Could this wiring harness be my problem?
Old Aug 4, 2024 | 08:26 PM
Prototypemech's Avatar
Prototypemech
Here's the wiring harness for a 1994 truck. First thing I would do is use a multimeter to ensure you have 12 volts going to the alternator. Sometimes the fuseable links burn out.
And make sure your charge indicator light isn't burnt out.
speakerfritz
6.7L Power Stroke Diesel
Feb 24, 2021 07:33 AM
rebelmedic
May 27, 2010 02:24 PM
WildPferd
Bronco II
13
Feb 19, 2009 11:02 AM
GeneStoner
May 21, 2005 05:32 PM
robjef
Jun 25, 2003 03:35 PM
