Electric Fuel Pump, Carburetor Flooding
Old Aug 4, 2024 | 01:03 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Floats are notorious for sinking. You said it started acting up, what was it doing?
There is usually only one needle and seat in a typical carb kit are you sure it wasn't the old one from when he rebuilt it?
Old Aug 4, 2024 | 01:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Many of the new needles and seats in rebuild kits are poorly made and don't seat well. Check for burrs on the seat.
Holley makes a nice regulator, and what I like about it is that they sell replacement parts for it. Holley 12-804 regulator, 1 - 4 psi output (adjustable). They used to be a lot cheaper, but they are good quality.
https://www.summitracing.com/parts/hly-12-804
Old Aug 4, 2024 | 01:53 PM
Bob2246's Avatar
Bob2246
Originally Posted by hooler1
Yes that does happen. It may not be common but it happened to me with a brass float. If you pull the float off and shake it around a little can you find gas leaking out of it?
When I had it apart I did give it a shake, but didn't hear anything.
The truck stutters when I press on the accelerator pedal because the throttle body is receiving too much gas. After the first time this happened (above in this thread), I barely could step on the pedal, and had to just feather it in order to baby it home. After pushing it in the garage, I turned the key to run but didn't start it. The fuel pump ran, and I witnessed gas pouring into the throttle body and past the float bowl gasket almost immediately.
Today, after replacing the needle valve and seat, I replaced the card and ran just the fuel pump for about 15 seconds, and saw nothing out of the ordinary. I started it and let it run in the driveway for 5 or so minutes. Still good. Took it for a ride, and began to experience the same trouble after about an 1/8th mile. Again had to feather the gas to get it home.
The parts looked new. I don't think they were previously used and taken out of service.
Old Aug 4, 2024 | 02:56 PM
truckeemtnfords
What ever was in the needle/seat that caused your flooding may now be in the jet(s) or another passage causing your issues. Maybe not but if crap got introduced into the carb a total inspection is warranted.
Old Aug 13, 2024 | 09:21 AM
Bob2246's Avatar
Bob2246
I found that a gasket was missing between the inlet needle valve body and the float bowl wall. I re-assembled with that, and put a new float in since I bought one (the old float is still above water on my workbench). It seemed to run ok, but was still I apprehensive because of the gas that was spewing from the float bowl gasket when the malfunction occurred.
I installed a fuel pressure regulator, and set it to 3 psi (running). I assume that high fuel pressure from the electric fuel pump compromised the gasket(?).
Fingers crossed.
Thanks to everyone who offered suggestions.
Old Aug 13, 2024 | 05:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you add a filter ahead of the regulator? They typically have a smaller ball and seat than the float, so are more sensitive to crud.
CorbinG
Mar 6, 2023 10:36 AM
Jimbus
Large Truck
Oct 29, 2019 07:20 PM
F350-6
21
May 23, 2014 09:33 PM
pinkpantherbeekeeper
Jun 18, 2013 03:58 PM
danlee
Apr 29, 2004 09:14 PM
