F150 sputtering
Old Aug 2, 2024 | 09:15 PM
Jaxlee's Avatar
Jaxlee
1st Gear
F150 sputtering
I have a 1994 f150 with a 4.9 in it. Recently when driving the truck it will randomly sputter hard and act like it's not receiving any fuel. After I'm done driving both fuel tanks will have enough pressure in the tank to push gas out of the cap if you open the cap just a hair. I've recently had the fuel pumps replaced and the issue wasn't there before the replacement. Do I have two faulty fuel pumps?
Old Aug 2, 2024 | 11:23 PM
Soup bean's Avatar
Soup bean
I would definitely talk to whoever did the fuel pump replacement.
Your fuel pumps should have a built in check valve to prevent cross filling.
Another possibility is that the EVAP system is damaged or not intact.
Here are pictures of the EVAP lines from my '88.
The EVAP system vents fuel vapors to a charcoal canister in the engine compartment, which then is vented into the intake via a solenoid.
Are you using factory fuel caps or aftermarket?
Old Aug 4, 2024 | 06:05 AM
manicmechanic007's Avatar
manicmechanic007
Drive the truck around with a fuel pressure gauge taped to the windshield
Your rollover vent valve is no good if it will not vent the tank
It might just be stuck
Remove that vent valve and smack it around some, see if you can get it to flow air out the tube
Old Aug 4, 2024 | 07:03 AM
My4Fordtrucks's Avatar
My4Fordtrucks
…or the hose got pinched when the tank was reinstalled.
Trucknightmare
Jun 4, 2023 12:23 AM
CPal
Sep 20, 2022 11:07 AM
jonmammenga
Feb 28, 2017 08:00 AM
wog1972
Sep 4, 2016 09:54 AM
