Knocking after changing spark plugs
Old Aug 1, 2024 | 05:05 PM
Trestyn's Avatar
Trestyn
4th Gear
So I have a '95 F150 4.9L with 228k miles on it. I recently just changed to spark plugs, ignition coil and wires. We tried to do the distributor cap but it didn't fit properly and we swapped back to the old one. After we put it all back together and firied it up it started making a like knocking noise. If anyone has any ideas on what that could be I'd appreciate it.
Edit: I should mention the sound does go away when we disconnected the spark plugs so we don't think a rod.
Another edit: We went from copper to platnium plugs because that was all that was available. Idk if that will cause the knock but it may be necessary information.
Old Aug 1, 2024 | 05:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Crossed a wire or two?
Old Aug 1, 2024 | 05:23 PM
Trestyn's Avatar
Trestyn
4th Gear
No we double and triple checked the diagram from the firing order.
Old Aug 1, 2024 | 09:24 PM
Junktownbill99's Avatar
Junktownbill99
I think he's talking about cross firing, voltage jumping wires.
Old Aug 2, 2024 | 08:48 AM
FuzzFace2's Avatar
FuzzFace2
Crazy things have happened when you dont run copper plugs in older motors like ours.
You said " the sound does go away when we disconnected the spark plugs" pointing to plugs.
I hope they are not too long and hitting the pistons then again it would close up the gap I guess?
Some will not have issues and others do we just dont know why that is so
Go back to copper plugs and see what happens.
Dave ----
Old Aug 2, 2024 | 09:45 AM
1Butcher's Avatar
1Butcher
Ok, this does not make sense to me but I got to ask. If you disconnected the spark plugs, the engine would not run and therefore, the noise would go away.
So, using a different set of words, what are you saying?
The more people that go under the hood, the more problems you will have. Funny how the factory rarely has problems but the more the hood is opened, the more problems you get. Is it possible that someone in the past removed the distributor and the rotor is not pointing in the right place? I know this should not effect the noise since all you did is opened the hood, replace plugs, coil, and wires so if the rotor is not right, it was not right before you started.
Old Aug 2, 2024 | 04:30 PM
Scndsin's Avatar
Scndsin
Simple test. Clean (original) plugs, re-install.
Noise goes away, buy Motocraft coppers.
Old Aug 2, 2024 | 08:48 PM
FuzzFace2's Avatar
FuzzFace2
I think (guess) he grounded the coil wire so the motor would not start only crank, and did not hear any knocking like a rod knock so he thinks it is only when running.
Thing is he is not running factory copper plugs just some high $$$ fancy plugs.
Dave ----
Old Aug 3, 2024 | 06:59 AM
Trestyn's Avatar
Trestyn
4th Gear
Dave ----
Swapping back to copper might be the play here. We just didn't have many options when we went looking for plugs. Might also have to double check they're all tight too. I talked to a mechanic saying that if their loose they make a popping sound that's nearly indistinguishable from a mechanic tick.
Old Aug 3, 2024 | 07:02 AM
Trestyn's Avatar
Trestyn
4th Gear
We ran a test where we cut power to the plugs from the distributor cap to just crank the engine without actually starting it to listen for the sound. We wanted to make sure it wasn't coming from lower down in the engine. The sound only happens while it's running and isn't rhythmically consistent.
Old Aug 3, 2024 | 08:45 AM
My4Fordtrucks
No. I was thinking that the wires got put on the wrong cylinders but that could be possible with cheaply made wires.
Dave ----
Definitely would not hurt to try that.
Old Aug 3, 2024 | 04:37 PM
FuzzFace2's Avatar
FuzzFace2
I dont see how you did not have options for the copper plugs?
If that was the case I would not have bought the plugs there and gone to a different store for them.
I guess a loose plug could push compression out but when I had a plug blow out on a 460 in a van that sits right next to the driver / passenger I never heard anything before it was out
Dave ----
Old Aug 3, 2024 | 08:05 PM
1Butcher's Avatar
1Butcher
FYI, I have Platinum plugs in my 5.8L and for over 20 years, I've had no problems [no, not the same set].
Old Aug 4, 2024 | 12:01 AM
MountainManRobb's Avatar
MountainManRobb
If you have a very well insulated set of pliers and a leather glove, pull a plug wire at a time of the distributor cap. If the noise goes away with a specific cylinder disconnected, then you now have a place to begin looking for a problem. FYI, just cranking an engine with the ignition system disconnected is not going to do much for diagnosing a noise. Even a severe roof knock can go away if you cut the spark to the cylinder.
Old Aug 4, 2024 | 07:58 AM
FuzzFace2's Avatar
FuzzFace2
Some have not had issues like you and other have had issues.
We dont know why that is but if something is not right after you installed fancy plugs like the OP swap them out and see what happens.
He also has a 4.9 so dont know if that has something to do with it?
Dave ----
danthemab
May 29, 2024 06:50 AM
ogarcia434
Jul 13, 2016 10:59 AM
redbeast
May 29, 2005 05:13 AM
kmgplus3
Jun 28, 2003 10:31 AM
