Fog Lights
Old Nov 28, 2003 | 12:41 PM
John OO's Avatar
John OO
Angry Fog Lights
96 explorer for lights are not working. Checked out fuses and they are ok. Found the relay box infront of air filter and I am not getting 12vdc to the relay. Relay seems to be working ok as I can hear it clicking when switch is turned on and off. Does anyone have a schematic for the fog light system? I'm trying to see where the 12vdc is coming from. Thanks
Old Nov 28, 2003 | 07:33 PM
golfboy17's Avatar
golfboy17
I would check the bulbs, in the fog lights, am not sure if you can just replace the the bulb or the whole assembly, the bulbs tend to go bad alot
Old Nov 29, 2003 | 03:32 AM
95limited's Avatar
95limited
Is the fog light switch lamp coming on? Have you tried jumpering across the relay? The 12 volts should be coming from fuse 15 in the power distribution box.
Old Nov 29, 2003 | 02:15 PM
20explorer00's Avatar
20explorer00
see if there is power going to the connector at the bulb
Old Nov 29, 2003 | 09:18 PM
Cm snipe's Avatar
Cm snipe
yeah one of my fog lights on my 96 X went out more then likely if there the stock lights youll need to replace the bulbs. all you do is look on the back there should be a gray know with the wire coming out of it.twist it to the left i believe to unlock it an pull it out an just pull the bulb out an slam a new one in an your lights should come back on
Old Dec 1, 2003 | 06:28 AM
John OO's Avatar
John OO
The switch light will not come on. I checked the relay, the relay is clicking when the switch is pushed in. There is no power at the one side of the relay coming from the fuse box and when I supply 12vdc to the relay terminal that goes to the fogs the fogs work.
ilbigmike
Jul 14, 2009 03:07 PM
m000996
Electrical Systems/Wiring
Mar 23, 2007 07:37 PM
philips
Nov 28, 2006 11:44 AM
casey38boost
Mar 21, 2006 07:06 PM
