pedestal assemblyoil leak?
Old Nov 28, 2003 | 12:03 PM
95psddrw's Avatar
95psddrw
i have 95 psd f350 308,000 milesand still strong.have leak at a linkage rod from pedestal assembly,ford wants $600 for new assembly also wants exchange.can this be rebuilt easily and cheaper any info on situation wood b appreciated
Old Nov 29, 2003 | 09:13 PM
mueckster's Avatar
mueckster
A revised seal is available from Ford to repair the leak from the EBP actuator. The part # for your '95 is 2C3Z-9P466-BA. I found this info on dieselmann's page. He is a Ford technician who provides free info for diesel owners. The pedestal will have to be removed in order to replace seal (involves removing turbo also). Be sure to replace O-rings under turbo. Seepage is normal, but if it's leaking bad you'll have to replace the seal or pedestal assembly. I have not replaced one as yet, but it seems to be a fairly straight forward operation.
Old Nov 30, 2003 | 06:02 PM
95psddrw's Avatar
95psddrw
Thumbs up thankx for info
thanks mueckster for info. will check monday on seal availability. let u know how replacement goes later!
fleonardis
Mar 16, 2013 07:16 PM
rog2554
Apr 1, 2008 04:38 PM
ldfry001
Mar 13, 2008 09:54 AM
stroker393
Dec 1, 2004 10:09 AM
