Sponsored by: Real Truck
AC issues
Old Jul 30, 2024 | 03:59 PM
DeeDubz's Avatar
DeeDubz
AC issues
Im sorta a novice when it comes to ac but I have a 2011 F250 6.7 diesel with 130k on it. The temperature in socal is in the 100s most days. It seems like my AC system isn't cooling. Or its just taking a long time blow cold. 4 months ago my expansion valve went out. I had no idea that was the issue. But I was able to rule out the major components. The truck was taken to a family friends auto shop. After they fixed it they said everything was fine. Right now it seems like its not working at its full capacity. Ive done google searches with really now luck. I dont really wanna take my truck into the shop again for this issue. Plus this truck is a 2011, I understand that its not going to work as good as a new vehicle. Hoping someone can give me some advice on where to go from here.
Thanks
Old Jul 31, 2024 | 07:27 AM
bajaphile's Avatar
bajaphile
A manifold gauge set will help diagnose a lot of issues with the AC system. Very high probability the system is low on R134a and needs a few ounces. You probably have a slow leak somewhere. I read in the Workshop manual that Ford systems come with UV Dye in them already, but I added R134a with some added when mine was low to help find any leaks. I have to add about a half to 3/4 can every 1-2 years to bring the pressure up to spec. (Still looking for my leak!). Other easier items are cleaning the evaporator and condenser which should be checked regardless.
Old Jul 31, 2024 | 09:49 AM
Eman85's Avatar
Eman85
If your family's friend has a recovery machine have them recover the freon and you'll know if it leaked. If they charged it they should have put some UV dye in and they should have a blacklight to leak check it.
ACADguy
2021+ F150
21
Aug 3, 2024 08:11 PM
billyalexander
Aug 10, 2022 06:35 AM
FordPickMeUp
May 25, 2022 02:32 PM
Dave2350
Apr 20, 2017 09:41 AM
jh818
S. California Chapter
Mar 24, 2013 12:47 PM
