89 manual hubs
Old Nov 28, 2003 | 12:02 PM
oceanadec25's Avatar
oceanadec25
Question 89 manual hubs
I have an 89 F150 4x4 and im trying to replace the front rotors. I removed the 6 screws and cap, then the actuator and the snap ring. At this point ive been told that the rest of the inside of the hub should slide out. It isnt. I tried putting a puller on it but the bolts looked like they were ready to snap so I stopped. What could be holding it in?
Old Nov 30, 2003 | 11:43 PM
Superdave's Avatar
Superdave
oceanadec25
There should also be another big retainer ring around the inside diameter of the wheel bearing, hub body.
This is laying right against the lock out hub body keeping it from sliding out.
Wipe the grease away and get a light, you will see it.
Old Dec 1, 2003 | 12:07 AM
JerichoM1070's Avatar
JerichoM1070
How do you go about getting that seconed ring off? I didn't see any kind of holes for a snap ring to get it out?
Old Dec 1, 2003 | 10:36 AM
mtflat's Avatar
mtflat
I use a sharp pick to get hold of it. A sharp, thin screw driver might also work. Pry up an end and then grab it with needle nose pliers. It's just a round wire spring.
Old Dec 1, 2003 | 12:46 PM
JerichoM1070
When I break it getting it out, what do I call it at the parts store?
Old Dec 1, 2003 | 02:41 PM
blu's Avatar
blu
It won't break.
I'd call it the outer race retaining ring or something similar.
A little bit of patience a couple of small flat head screw drivers to pry it out and you're good to go. Don't forget to pack your bearings and while doing the rotor.
Good luck
Old Dec 1, 2003 | 11:49 PM
Superdave's Avatar
Superdave
I use the thin flat bladed screwdriver method.
Old Dec 2, 2003 | 12:36 AM
borin&strokin's Avatar
borin&strokin
A piece of broken piston ring sharpened on the grinder was the best thing I found. Unless you can afford a GOOD set of dental-style picks.
spudgunman
17
May 28, 2023 08:19 PM
VORTMAX_99
Nov 26, 2016 12:16 PM
kidoo
Sep 23, 2011 11:25 AM
ccoram
Mar 28, 2008 03:16 AM
TwoF150
18
Apr 24, 2003 07:54 AM
