Heater hose routing
Old Jul 30, 2024 | 10:07 AM
76F250SuperCab's Avatar
76F250SuperCab
Heater hose routing
Does anyone have the correct routing diagram for the heater hoses in a 63 Econoline 2.4? I'm replacing radiator & water pump & cleaning heater core and it looks like it was jerry-rigged with a t fitting coming out of the petcock radiator hole.
As it was installed un petcick(clogged)
Old Jul 30, 2024 | 12:23 PM
theoneandonlyjonasv's Avatar
theoneandonlyjonasv
Maybe one of these drawings may help you:
https://econoline.org/drawings.php
Old Jul 30, 2024 | 03:01 PM
76F250SuperCab
Thanks for the info, I'll check it out.
Old Aug 6, 2024 | 08:00 PM
EmilBarnabas's Avatar
EmilBarnabas
Drawing of the exploded view of the 1961-1964 heater. 1961-1964 Heater
Old Aug 7, 2024 | 08:57 AM
76F250SuperCab
Thanks this will help but is there a diagram where each of these heater hoses terminates(water pump etc)?
Old Aug 13, 2024 | 08:29 PM
EmilBarnabas
Here is a drawing that shows the heater hose that connects to the front of the head and to the carburetor spacer.
https://econoline.org/drawing.php?d=A2005-B
Old Aug 13, 2024 | 08:35 PM
EmilBarnabas
Here is the same drawing but with part numbers. The part numbers have more detail below the drawing.
https://econoline.org/drawing.php?d=P-4833
Old Aug 13, 2024 | 08:45 PM
EmilBarnabas
This exploded view of the heater gets the hoses to the engine, but does not show how they connect. One heater hose connects to the water cut-off valve (at the heater), then to the carburetor spacer, and goes through the spacer to the front of the head. The other heater hose connects to the water pump.
https://econoline.org/drawing.php?d=P-3296
Old Aug 14, 2024 | 08:22 AM
76F250SuperCab
Thanks again. I guess I should have looked closer to the small printing on the diagram. Why mine was T'd onto the radiator drain had me wondering.
Old Aug 14, 2024 | 04:29 PM
EmilBarnabas
The small print on the drawing was added last night, so you didn't miss anything.
seijirou
43
Jul 5, 2022 12:15 PM
Nicmike
Dec 9, 2019 01:42 AM
AtlM5
Jan 7, 2015 07:14 PM
victorcharlie
Nov 21, 2011 03:31 AM
Daves94vert
Dec 19, 2007 05:54 PM
