Sponsored by: Real Truck
Power folding side mirror
Old Jul 29, 2024 | 07:04 PM
timwill's Avatar
timwill
Trailering
I have a 2013 F350 Lariat CC 4x4. The drivers side power folding mirror has started acting up. Sometimes it works flawlessly, other times it works partially. I always hear the motor running but it will fold or unfold part way and it makes a popping sound. Is this fixable or does it need replacement? Thanks
Old Jul 30, 2024 | 06:45 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I don't know that it is fixable, it might be, but replacement tends to be costly. I have heard some of these mirrors, depending on options, can run north of $1k/each. Unless you can find one in a junkyard.
Old Jul 30, 2024 | 02:01 PM
CFLSuperDuty's Avatar
CFLSuperDuty
4wd Low
Try this website, they offer metal gears for the housing. I your gears are wearing, i would give these a try. https://www.gruvenparts.com/shop-by-car/ford
Old Jul 30, 2024 | 06:39 PM
madsonp's Avatar
madsonp
I’ve seen some videos where it’s fixable, but it looks like a pain in the a$$, my mirror on my 2012 was doing the same thing, I was able to find a Ford OEM mirror on a Ford parts website for about $360, which is the heated, power, folding, and telescoping, changing it out was pretty easy. I don’t remember the website right off hand, I’ll look around and see if I can find it.
Old Aug 3, 2024 | 11:03 AM
tired mechanic's Avatar
tired mechanic
8th Gear
Had the same problem on my2011 F250. I took the mirror to the bench and took it apart using the info from the link above in post #3.
I cleaned and greased the pivots and now it has been working fine.
It is a real pain in the a$$ to work on.
KevinMook
Feb 15, 2024 12:09 PM
Gwilkrrs
Feb 24, 2022 03:25 PM
woodhead
Jul 22, 2016 08:46 PM
