Parts swap ?? 78 bronco to 79 f-150
Hello, I have a 78 bronco that I would like to swap the steering column,steering box and shaft over to my 79 f-150 4x4. The bronco has tilt/cruise and the 150 doesn't . Are the wire connentors the same on each vehicle? direct bolt/plug in?
Also the bronco has sway bars front and rear and I would like to swap rear ends, is the front sway bar easy to swap to the 150?
Thanks
Thanks
Thanks for the replys!!!
My F-150 has a loose steering gear box and steering column w/ bad bearings and turn signal switch that is bad. The wire connectors are my biggest concern, I don't want to redo the factory connectors.
My rear end the posi has worn clutches and a yoke that leaks and grease seal on the right side that leaks.
I bought this bronco w/ tight steering and the former owner was a driveline mech. who rebuilt the rear end a few years back. I have already swapped out the door panels and plan on getting what I can of off the bronco before sending it off. I plan on getting the transfer case & front end also. The bronco has a skid plate for the gas tank, would that work on the 150?
Thanks again for the HELP!!!
Originally posted by hilslider
i'm looking at a 78 brono also the doors will fit on a 79 f150?
and what will it take to bolt in the bucket seats on my truck
thanks gary
thanks gary
Marty
Da_Lariat_Chariot
02-11-2015 01:44 PM
JB78f150
02-22-2012 11:27 PM
crazed87bronco
06-22-2011 12:49 AM
