Fuel Filter Part #'s
Old Jul 24, 2024 | 08:16 AM
Boostingaz's Avatar
Boostingaz
Can anyone confirm the correct part numbers for the OEM fuel filters that I should be using on a 2022 F450.
Just coming back from several Ram's in a row and need to get my common maintenance part number list filled out to have on hand again.
Thanks in advance.
Old Jul 24, 2024 | 09:15 AM
4wd6.7L's Avatar
4wd6.7L
FD-4641 is the filter set 17 and up. There is a new part# (FD-4647) that looks to have some improvements, but last I checked it was only listed for 23 and 24.
Old Jul 24, 2024 | 09:25 AM
Boostingaz's Avatar
Boostingaz
Thank you sir.
Thoughts on the H&S front fuel filter upgrade to change it to a Baldwin spin-on to get rid of the plastic housing. Worth it or failure rate is fairly low?
Old Jul 24, 2024 | 10:02 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You can also use the FD4625AA filter set, just has the extra support collar for the one breakage prone fitting for the earlier trucks, same filters though, and many times can be had cheaper.
Old Jul 24, 2024 | 10:05 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Originally Posted by Boostingaz
Thank you sir.
If you care about your warranty on the issue prone fuel system, any change like that will void the warranty.
Erie660
6.7L Power Stroke Diesel
16
Nov 5, 2024 07:38 AM
Beachbumcook
6.4L Power Stroke Diesel
Jul 12, 2010 10:44 AM
MIKE1646
Jul 7, 2010 02:10 PM
Superdudey
Jun 26, 2007 12:45 PM
ultramag
Apr 4, 2007 09:44 PM
