9" Ford axle question
Old Jul 23, 2024 | 01:49 PM
Jeff Wecker's Avatar
Jeff Wecker
I currently have 3.54 gears in my 1973 F100. I want to find something more highway friendly, like a 2.73 or 3.08 center section.. What I need to know, is what axle code I need to look for,to get what I need. Also, what years will work, and what axle spline count I need.I do not do any towing, it is mainly for cruising
Thanks
Old Jul 23, 2024 | 02:11 PM
tbear853's Avatar
tbear853
I made a trailer from rear half of a '79 automatic 351M wrecked F-150, I believe it had 2.75:1 when I removed them. Maybe was 2.73:1 .... was a good 30+ years back.
I guess I should have kept them? I am totally happy with my trucks 3.50 rear, from Main to Alabama, south Georgia, points in between, but 60-63 is the sweet spot.
Old Jul 23, 2024 | 02:30 PM
68Flareside240's Avatar
68Flareside240
Just get the ring and pinion you want and throw them in there. Ford 9" is pretty easy to do.
Old Jul 23, 2024 | 03:06 PM
jflem's Avatar
jflem
Attached pictures show the axle codes for the trucks.
Old Jul 23, 2024 | 03:27 PM
dlburch's Avatar
dlburch
are you 100% sure you have a 9" rear diff?
Old Jul 23, 2024 | 04:05 PM
85e150's Avatar
85e150
3.54 is a Dana ratio. Ford is 3.50. You may find a 3.54 in front and 3.50 in back with a 4x4 for example.
If it's a Dana, 3.54 is it afaik.
Old Jul 23, 2024 | 05:27 PM
68Flareside240
Whoops may have jumped the gun there. Forgot they put Dana’s in half tons.
Old Jul 23, 2024 | 05:40 PM
85e150's Avatar
85e150
Hhhhmmm. I think '79 is past the era of Dana 44s in F100s as the limited slip option.
OP needs to check.....
Old Jul 24, 2024 | 05:47 PM
BLK79's Avatar
BLK79
I swapped 3.00 gears in place of 3.50 in both of my 79 Broncos. Way more comfortable at highway speed. 80 mph is no biggie.
KLEO1480
Mar 2, 2013 06:53 AM
CharlieLed
May 22, 2012 08:18 PM
old red 73
Sep 6, 2011 03:09 PM
MAULMAUL
Apr 9, 2011 02:32 PM
