Neutral Safety Switch - Help
Old Jul 18, 2024 | 08:05 PM
Jacksanchez4351's Avatar
Jacksanchez4351
8th Gear
Question Neutral Safety Switch - Help
Hello All!
I have recently converted my 1972 F250 from a manual transmission with manual steering to a power steering and automatic transmission setup. Everything has been working fine until I realized that it does not have any wiring for the neutral safety switch since the manual transmission does not have one. I have tried searching schematics and wiring instructions but I have not found anything for my situation. Any advice or suggestions you have would be greatly appreciated! Thanks in advance.
Old Jul 19, 2024 | 12:13 AM
Green72F250's Avatar
Green72F250
Here is a good thread that talks about the neutral safety switch with some pictures. Your truck should have a bi-pass wiring connector in your under dash wiring harness. Here is a picture of what it looks like. The neutral safety switch wiring plugs in that location.
Neutral safety switch don't work now? - The FORDification.com Forums
Old Jul 19, 2024 | 04:38 AM
Crop Duster's Avatar
Crop Duster
Originally Posted by Jacksanchez4351
Hello All!
First thing you need to do is say what engine and what transmission and where they came from.
All the neutral safety switch does is break the connection between the ignition switch and the "S" terminal on the start relay. If your column has the NSS on it all you have to do is locate the wire going to the "S" terminal and run it thru the NSS.
That said all this only works if you used a transmission from a truck with the correct manual lever on it and the shift linkage from a truck. The biggest mistake people make is installing a transmission from a car or truck that doesn't have the correct manual lever in it. In that case the stars won't line up.
Old Jul 19, 2024 | 11:29 AM
Jacksanchez4351
8th Gear
Great thanks for the information! I will take a look at that today!
Old Jul 19, 2024 | 06:41 PM
davelj's Avatar
davelj
The factory N/S switch would have been on the steering column, under the dash. My column was damaged and I couldn't use that style switch. Since my truck has a later trans, it had the provision for a N/S switch on the side of the trans. I used a switch from what I think was a late 70s E150 which came with a long lead which reached the harness under the dash.
Old Jul 20, 2024 | 06:10 PM
Green72F250
Did you get this figured out?
Old Jul 23, 2024 | 06:57 PM
72bumpside's Avatar
72bumpside
I have this dangling from my steering column. Not sure of the history but I’m guessing someone switched out the steering column for a power steering addition. Only reason I haven’t tucked it away is because on cold mornings I often have to give it a light tap with the side of my foot in order to start her up.
Old Aug 1, 2024 | 05:44 PM
Jacksanchez4351
8th Gear
I did not get it figured out as I was not able to find that bypass wiring in the under-dash wiring harness. The picture you attached earlier was very helpful but I was not able to find it anywhere. I have to remove the instrument cluster in a few days so I will look again once I do that. My biggest concern is making sure that the backup lights are working as it appears that is connected to the neutral safety switch wiring.
Old Aug 1, 2024 | 05:59 PM
Green72F250
Maybe this will help:
Old Aug 1, 2024 | 06:03 PM
Green72F250
It's my understanding that the Black/Red stripped wires are for reverse, and the Red/Blue stripped wires are for the Neutral Safety Switch.
Old Aug 1, 2024 | 06:14 PM
Green72F250
This is from a 1968 or 1969 but it should be similar:
Old Aug 2, 2024 | 10:39 AM
Jim_K's Avatar
Jim_K
You don't have to remove the cluster for this, as everything is located on the top of the steering column, roughly right above your ankles. If you can't see up there (lack of light), you should be able to at least feel for it. There should be a small lever or bar sticking out of the top of the steering column that moves back and forth (L & R) when you move the shift lever, and the NSS is spring loaded to ride up against it.
Old Aug 2, 2024 | 12:42 PM
72bumpside's Avatar
72bumpside
I’m still new to this truck, but if he had a manual converted to automatic, he’s not going to have any of that (switch assembly sticking out of the steering column). I thought the reverse lights were triggered by a switch at the transmission in the manual models.
Again I may be wrong but I thought manual models didn’t have that switch.
Old Aug 2, 2024 | 01:40 PM
Jim_K's Avatar
Jim_K
I'm slapping myself upside the head a bit here, as somehow I thought your response in reply #7 was from the OP!
But all may not be lost, as who knows? Perhaps the truck originally had an automatic...or the steering column was swapped....
(Just trying to dig myself out of the hole here!)
Old Aug 15, 2024 | 08:42 PM
Jacksanchez4351
8th Gear
Update
Hi All,
Your help has been so great! I have fixed the neutral safety switch portion but the backup lights are not working. I know that wiring is associated with the NSS but it didn’t fix that issue. With it going from manual to auto I’m not sure what else needs to be done. Any help is appreciated!
