Fuse frustration
Old Jul 18, 2024 | 07:27 PM
scottz99's Avatar
scottz99
Veteran: Navy
Fuse frustration
I will be heading out on a long trip soon and decided to make sure I had the correct spare fuses. It’s pretty frustrating that the owner’s manual tells you the fuse amperage and what it’s used for, but not the type of fuse. I had to physically check all of them to figure out the type. Micro2, Slotted Mcase & Low Profile Jcase in the under-hood panel. Micro2 and Micro3 in the BCM fuse panel. I couldn’t find a kit with all these, had to buy three seperate kits.
Old Jul 19, 2024 | 04:58 AM
Smokeatrr's Avatar
Smokeatrr
When have a complete the list of fuses needed I would like to see it. I try to carry extra fuses also.
Old Jul 19, 2024 | 05:19 AM
Black Buzzard's Avatar
Black Buzzard
I havent had to replace any fuse in any of my last 10 vehicles going back to 1996.......many many miles driven. If a fuse blows there's a concerning overcurrent situation going on, and replaced fuse will likely blow again. That said I still pack a bunch of fuses along with a multimeter in my travels.
Water pumps, fuel pumps, alternators, coil packs, starters, radiators, its a different story. Much harder to pack all these as spares isn't it.
If some dude assembled a complete 2022 gas superduty specific fuse and relay set on ebay, I'd be looking at it.
Old Jul 19, 2024 | 01:56 PM
scottz99's Avatar
scottz99
Veteran: Navy
That's right, I will probably never use them. However, it would be a problem if one of these unusual fuses blew while I'm in Yukon.
Old Jul 19, 2024 | 02:08 PM
scottz99's Avatar
scottz99
Veteran: Navy
Here is the list of fuses in my truck; a '22 F-450. YMMV.
Unfortunately, I couldn't find one place that had everything I needed. Not interested in junk; I like Littelfuse or Bussmann.
Purchased individual Low Profile Jcase fuses here:
Low Profile Jcase
Purchased these kits:
Slotted Mcase Slotted Mcase
Micro2 Micro 3 Micro2 Micro 3
(also has Mcase, but don't think I need them)
If anyone sees any errors with this, let me know.
File Type: pdf
Old Oct 19, 2024 | 06:31 AM
George in NH's Avatar
George in NH
Smile
Hey scottz99, that was some very helpful info, especially the pdf, which is now printed out and in my truck. THANKS
Low Profile Jcase
Slotted Mcase
Micro2 Micro 3 (also has Mcase, but don't think I need them)
Old Oct 19, 2024 | 08:16 PM
Lariat Driver's Avatar
Lariat Driver
Veteran: Navy
Thanks for the list!! I also tried to figure out which type of fuses were in my 22 F-250, in certain positions, when I did a couple of mods earlier. Bought a couple of packs based on the names in the OM. That didn't work very well. Ended up not needing any spares but I still want to gather a kit for our trip to Alaska. Appreciate the links also.
Old Oct 20, 2024 | 10:56 AM
greenno's Avatar
greenno
Just went through this process a few weeks ago on my 2019 F350 6.7l.
My rear 12vdc outlet quit working and I checked and the fuse had blown.
I was lucky all the fuses listed in my owners book/manual had the specific type and rating.
So I double checked the fuse panel under the hood and also on the passenger side legroom area to see which fuses I actually were using as the manual lists every possible fuse for all option’s available.
When I replaced the bad fuse I made a list of spares I could possibly need and loaded them up in a small plastic case I had and now they rest under my front middle storage area in case I ever need them.
1996f3507.3
Apr 16, 2010 07:28 AM
mdacton
Oct 10, 2008 05:10 PM
mackjones23
1983 - 2012 Ranger & B-Series
Mar 22, 2008 08:30 PM
mmmPowerStroke
Jan 4, 2006 07:14 PM
lynxcat
Mar 12, 2004 07:01 AM
