Weak shocks already?
Old Jul 18, 2024 | 12:38 PM
jds535's Avatar
jds535
I just traded in my 2016 F150 XLT crew cab 5.0L due to engine problems. I bought a 2022 F150 STX crew with a 2.7L . I really like the truck but it is not as stable as the 2016 was. What I mean to say is that it kinda dips and sways like a boat on rough roads where my old truck was much more stable. If I open the door and push the cab to get the truck swaying back and forth it rolls back and forth at least 3 times. Seems like the shocks are blown, or very weak but there is no sign of oil leakage from them. The truck has 20K mile on it.
Is the 2022 know for weak springs ??
Old Jul 18, 2024 | 05:10 PM
ejkTN's Avatar
ejkTN
5.0L and 3.5L 2015+ 4x4 trucks get a ~7050 GVWR while the 2.7L gets a ~6650GVWR unless it has the 2.7L payload package option. As a consequence your payload is reduced and your springs are softer. As a 2.7L owner who also towed a 7000lbs travel trailer with it, I can say that adding the HD Roadmaster active suspension really firmed up the rear end on bumps, reduced body roll on turns by a moderate degree, and completely eliminated any wheel hop when I was having some fun launches. You may want to consider this product. Note that you can adjust the stiffness. Also note that it will raise the rear end by about an inch unladen which was my experience setting the HD-RAS to beyond the 1mm position but short of the 2mm position, probably around 1.25mm.
Old Jul 19, 2024 | 04:42 AM
jds535's Avatar
jds535
Thats good info, Thanks. That sure is a strange looking device. I will research it more. I dont really want to raise the rear any since its very apparently higher than the front already. I guess a leveling kit too? I wonder what that modification does to your warranty?
Old Jul 20, 2024 | 09:30 AM
jake415's Avatar
jake415
The OEM Ford shocks stink. That is at the very least a part of your problem. The Bilstein 6112 / 5100 struts and shocks solved that issue for me. Towing is much more enjoyable now too.
Old Jul 20, 2024 | 11:53 AM
JKBrad's Avatar
JKBrad
I never liked the factory shocks. I went with Eibach and have been happy with them.
Old Jul 21, 2024 | 06:31 AM
Fat Ford Boy's Avatar
Fat Ford Boy
When I was doing service writing work for the dealership, I can't count how many Expeditions, had shock problems.
I know that one owner ended up with at least 2 sets of shocks, because IMO, they are J U N K ! ! !
Old Jul 21, 2024 | 07:06 AM
RLXXI's Avatar
RLXXI
When my brand new 2013 had only 2300 miles on it, I discovered one of the shocks leaking, was in the process of installing a 4" lift kit that came with new longer shocks so it didn't matter but yeah. OEM shocks suck.
jds535
2021+ F150
15
Feb 19, 2025 05:12 AM
mikekerr
May 5, 2020 01:52 PM
Rooster403
1997 - 2003 F150
Nov 1, 2017 08:25 PM
jelzy
Dec 6, 2003 01:35 PM
