Just received our 04 F250 FX4 lariat crew cab two days ago. Came out of a 99 F250 lariat 2wd sc 7.3. Have noticed 3 things already that I do not like and would like to hear if others have noticed, or not, some of these same things. 1st, the cruise does not keep up with this truck. If you set cruise on 70 in the 7.3 it stayed there up hills,whatever. The 6.0 drops 3 to 5 mph on what i would consider small hills. 2nd, the brakes do not seem to be anywhere close to as good as the 7.3 even after 115000 miles.(99 still had 50%brakes left) Last of all,this truck seems to want to studder when backing up. Build date is 11/04. Thanks.
Regarding the cruise control, I think it is common for the 6.0's to loose 5 MPH at the bottom of any steep hill. Mine has been worked on once for it but there was no improvement.
ultraclassic: it means that you have the latest update installed and the label was sent to indicate that, you should be good to go...let me know if I can help.... I have included your oasis print...
1FTNX21P93EC79934
11/29/2003
07:09:55
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 SUPER CAB 4X4 ENGINE
6.0L DIESEL DI V8 ENGINE CALIBRATION
GENERAL WARRANTY INFORMATION
WARRANTY START DATE 11/14/2003
BUILD DATE 03/21/2003
SALE MILEAGE 00010
EXTENDED COVERAGES:
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY:
11/07/2003 DEALER: Frank Kennedy Ford
WARRANTY CLAIM NUMBER: 108763 ODOMETER: 000062M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
RECAL ECC PROCESSOR RECAL 000 03T02B 79 SPECIAL CODE: USE ON RECALIBRATE MODULES AS PER FORD PROGRAM
09/23/2003 DEALER: Frank Kennedy Ford
WARRANTY CLAIM NUMBER: 108068 ODOMETER: 000040M
LABOR OP
CONDITION CODE
CONDITION DESC
TDRIVE PDI TEST DRIVE 000 TDRIVE 82 FREIGHT/POSTAGE/MAIN
LABOR OP
CONDITION CODE
CONDITION DESC
000 03L12B
And in reponse to all of this, I have received calls today from people upset that I have provided this information, Just because the truck has an early build date does not mean that it WILL have problems, Just look at Tim larkins truck, it runs fine. If your truck has a driveability issue get it looked at! Not all the trucks run badly and if it does there are ways of dealing with it. I will not post any further help if this is not understood.....The late trucks with the "good" program and injectors will have problems also, I guarantee it. That is why every Ford dealer has and will keep a service department....
Mine has A 3/24/03 huntsville build have 8800 miles and have no problems with truck. Only thing is truck smokes on start up asked dealer said it was normal.Oh yea got a sticker in the mail to put on valve cover.
