Electrical Issues
Old Jul 17, 2024 | 06:27 PM
harleymc31's Avatar
harleymc31
Trailering
Electrical Issues
1995 F-250 7.3L with 385k miles. My wife was driving the rig this weekend while I was out of town, and experienced a range of issues I'm having trouble diagnosing.
At first the battery was low, so a neighbor hooked up jumper cables and it took 30 minutes before it would start. As she was driving, she noticed the speedometer wasn't working, as well as the other dials/displays. She was driving secondary streets and never got up over 40mph, but the truck was shifting at irregular RPM's and the shifts felt rough. After maybe 5 minutes of driving the engine quit and she pulled to the side of the road, then had it towed back to our house. At present if I try to start it, there isn't enough battery to even light the dash. Maybe a battery issue, but they're only a year old or so. Any ideas where to start?
Old Jul 17, 2024 | 06:55 PM
z31freakify's Avatar
z31freakify
I would start by checking the alternator, then check the GP relay to see if it didn't get stuck in the on position
Old Jul 17, 2024 | 06:56 PM
96SD's Avatar
96SD
Lots of threads here on batteries, grounds and replacing clapped out battery cabling. Thats where I would start.
Old Jul 17, 2024 | 09:48 PM
Hit Man X's Avatar
Hit Man X
30 year old truck with 400k, everything is suspect
Old Jul 18, 2024 | 08:55 AM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...ou-cranky.html
go through this hit list
Old Sep 18, 2024 | 05:41 PM
t.rigger's Avatar
t.rigger
6th Gear
check fuses I had a 92 f150 and I blew a fuse and it basically threw its self into limp mode and shifted rough
jp1993
Apr 20, 2023 09:30 PM
Draconwolff
2009 - 2014 F150
Aug 27, 2017 08:44 AM
sammatt1
Mar 24, 2014 01:00 AM
Lone Wolff
Electrical Systems/Wiring
Aug 10, 2009 09:41 PM
prohopwer
Nov 21, 2006 08:19 PM
