Jumping A/C Compressor.
Old Jul 14, 2024 | 01:47 PM
dunecj2a's Avatar
dunecj2a
94 F350 460 If I jump the pressure regulator switch off of the accumulator should the compressor clutch come on as strong as if the system was full of refrigerant and cycling normal.
Right now the system is completely empty except for 8oz of pag46.
Old Jul 14, 2024 | 02:33 PM
Hit Man X's Avatar
Hit Man X
No it will just run.
Vac down and gas it up. 38oz
Old Jul 14, 2024 | 06:39 PM
dunecj2a's Avatar
dunecj2a
[QUOTE=Hit Man X;21283173]No it will just run.
Vac down and gas it up. 38oz[/QUOTE
should the clutch engage just as strong with jumper and system empty, or does the clutch engage differently with no refrigerant.
I tested the compressor with the jumper on and the clutch engaged but seemed very weak.
Old Jul 14, 2024 | 06:49 PM
Hit Man X's Avatar
Hit Man X
Opinions vary, mine is why waste time with questionable parts unless you have receipts of their age? An entirely NEW system runs sub $500 installed (DIY). Truck is 30 years old.
If the clutch is weak, to me I would just amass parts and swap over a good weekend. I suppose you could check voltage here and there if you see fit, which would take five minutes.
What is your time worth?
Old Jul 14, 2024 | 06:57 PM
dunecj2a's Avatar
dunecj2a
my thoughts exactly…chasin and wastin sucks. Nickle and diming adds up to paper fast.
system is all new except for the compressor that worked before parking the truck for 5yrs.
Old Jul 14, 2024 | 07:00 PM
Hit Man X's Avatar
Hit Man X
Plenty of potential leak points. How long did last charge last?
My 96 7.3 leaks about one 12oz can every few years. Easier to shoot can into for now than rebuild.
skbishop90
18
Mar 15, 2023 05:58 PM
shortblock2000
Jul 3, 2010 09:28 AM
ubermich
Jul 2, 2004 03:29 PM
wosborn
Jun 13, 2004 10:31 PM
progravix
1983 - 2012 Ranger & B-Series
Jun 1, 2001 11:09 PM
