New shocks recommendation?
Old Jul 15, 2024 | 07:07 AM
  #31
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Based on the pictures in post #13 of your other thread, those do not look like the same 4600 shocks I bought for my 4x4 F-250. It is not surprising that the shocks have a different mounting method though.
My shocks were plug and play so to speak, as long as the installer had an impact gun to make the job easy.
Reading past post #13, it seems the 4600 shocks you bought do bolt right up?
For reference and future readers, the 4600's I bought came in a set of four consisting of part #'s 33-028187 and 24-185981.
Old Jul 15, 2024 | 07:40 AM
  #32
RacinJasonWV's Avatar
RacinJasonWV
After looking at the link to the adapter I think I understand the issue now. I see the part number you ordered has a photo of the 2 bolt style in the part description. Is that not the actual?
I poked around at Summit and see that options appear limited for a 4wd Ex. I wonder what a local part store could get you. That’s where dad ordered the Motorcrafts.
I also saw this one at summit listed for your vehicle. SN-24-185455
https://www.summitracing.com/parts/BSN-24-185455
The photo looks the same, I’m not sure what the real difference is. Maybe they just have 1 listed incorrectly?
edit: looks like this is for a 2wd.
Could give Bilstein a call to try and clear it up but they’ll likely just refer to the application chart on their computer which looks like it’s wrong. Maybe their tech line could help out?
Honestly, I’d probably try giving them a call and if nothing was direct fit then probably just order the $100 adapter brackets and be done with it.
Digging some more…
Here’s a search at Rockauto. https://www.rockauto.com/en/catalog/...k+/+strut,7556
The list they show may give you some part numbers to search for. They show Motorcraft, but only 1 available 🫤 ASH24433 They do appear available at Amazon though.
OK, just know before hitting the submit button I checked out your other thread again. I see you uploaded a photo of your new shock which does have the double bolt style. Does that mean that Bilstein corrected the issue and these are now direct fit?
Old Jul 17, 2024 | 07:41 PM
  #33
excursion_7.3's Avatar
excursion_7.3
@Racin and Sous...Yes, they fit perfectly with no modifications. Pain in the butt to install and compress overall though. The straps did not compress them to the degree that they needed to be compressed to...only allowed enough space for a floor jack and a wide socket to compress them. Certainly not a 10 minute job.
Old Jul 17, 2024 | 07:59 PM
  #34
kenn_chan's Avatar
kenn_chan
Originally Posted by Y2KW57
I would normally do that, but the responses on the other thread, in the other sub-forum, have been all business.
The responses here, on the other hand, have been all bar room (or pick any other b-word that comes to mind).
I resemble that remark.....
Old Jul 18, 2024 | 06:16 AM
  #35
RacinJasonWV
Great! Glad it worked out and you Excursion folks no longer need an adapter.
Next up you’ll have to come back and share a review on hope they handle.
Old Jul 18, 2024 | 08:04 AM
  #36
excursion_7.3
Thank you and would be happy to do so.
I only did the rears as I am short on time but what a difference. Much more firm. The shocks I removed had to be the originals as the top "shield" was seriously rusted out.
Does anyone know if that level of rust is common on these or is that completely unheard of?
Old Jul 18, 2024 | 08:09 AM
  #37
FordTruckNoob's Avatar
FordTruckNoob
Having been in MN for 20 years, I'd say it's pretty common.
Old Jul 18, 2024 | 10:06 AM
  #38
Sous's Avatar
Sous
FTE Emeritus
Good to hear you got the shocks fitted up. Strange to find out that they were a pain in the **** to get mounted though. My install took longer than 10 minutes too, but that was for all four and I did it with the tires on the ground as seen in the video below.
Hopefully you enjoy the new shocks as much as I have. My wife noticed the difference almost immediately without me giving any clues about them being replaced.
Old Jul 18, 2024 | 10:15 AM
  #39
excursion_7.3
@Sous - Yeah I am usually the unlucky guy. I am going to do the front now. Do you or anyone here know if the procedure is the same as your video for the Excursion 7.3 4x4 by chance? It's awesome that your wife noticed right away without your even hinting at it.
Thanks for putting this out there!
Old Jul 18, 2024 | 10:25 AM
  #40
Sous's Avatar
Sous
FTE Emeritus
I cannot say for sure the procedure is the same, but if the shock mounting locations look the same I would ***-ume they are the same procedure. Truly, I was/am impressed with the 4600's. The shocks I took off were well worn though, so they had an easy time of making things better.
I hear you about being unlucky. I fought a 2003 2.0 VW Beetle for a week this winter just to replace the water pump. The pump is run by the timing belt and requires the engine to be moved and adjusted in order to get the mounts out. I saved a boat load of money doing it myself though, as you likely are now.
You will get it done, walk away for a bit or a day if you have to.
Old Jul 18, 2024 | 11:20 AM
  #41
udsuth78's Avatar
udsuth78
Some of my best work happens after getting ticked off and throwing down my tools. Then in my best Cartman impersonation give a "Screw you guy I'm going home". The cooldown helps you think of a better way. There's always a better way.
Old Jul 18, 2024 | 02:01 PM
  #42
excursion_7.3
Lol, that is the thing. Once I commit to getting something I get it done but I have learned to procrastinate to avoid the job in the first place haha.
Funny...I too have a 2003 VW but it is a Jetta TDI Wagon. I know the feeling!
I do everything myself that I can. It's to the point of severe burnout though. If I bring it to a shop the work never gets done right so I just persist. Hands shaking, back aching and so forth.
It has gotten so bad that even on the Excursion I do manual tire changes and bubble balance even if it takes a while. Still balances out way better than it does at the shop and I don't have to go back 3 times to have it corrected.
Thanks for the inspiration.
Old Jul 18, 2024 | 02:02 PM
  #43
excursion_7.3
You got that right! Especially since I have other vehicles it can just sit for a while!
Irtnog
Mar 23, 2023 11:35 PM
Ford Big Rig
Apr 3, 2017 08:25 AM
97 F250 Heavy Duty
1997 - 2003 F150
Jul 31, 2007 02:03 PM
treb
1997 - 2003 F150
Aug 14, 2003 05:25 AM
