Excursion ac system malfunction
Old Jun 1, 2025 | 05:05 PM
  #31
01__Excursion's Avatar
01__Excursion
I haven't read back, but was the front orifice/strainer pulled to verify it's clean?
Old Jun 2, 2025 | 07:03 AM
  #32
Excurvelle's Avatar
Excurvelle
So, I have 2 Excursions. My 2000 is a stock system and will freeze you out. My 2005 has had tons of money put into it and really starts not cooling well at 90 degrees, it was horrible when we drove through the desert. So what is the difference? Cooling fan for diesel and gas are different and the 2000 is a standard control, the 2005 is EATC.
All components in the 2005 have been flushed or replaced except for the rear evaporator, rear expansion valve AND rear filter, yes, there is a filter. Cost for the filter is .50 at RockAuto. I am going to tackle the rear system, replacing the filter, expansion valve and evaporator. I will also be replacing the orifice tube and dryer --AGAIN--. The compressor has been replaced several times and IMO, the rear air has a restriction from debris.
https://www.rockauto.com/en/moreinfo...pt=15479&jsn=7
It frustrates me that the auction buy 2000 $2000 old farm truck Excursion will run you out being so cold and the 2005 Diesel, that has been overly maintained for 15 years, where I have spent thousands on it to fix the A/C does not perform well.
Old Jun 2, 2025 | 08:53 PM
  #33
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
My experience is similar. My 2001 6.8L gasser with manual controls will freeze my family out on a 90 degree day. My 2004 6.0L diesel with electronic controls is adequate at best.
Old Jun 3, 2025 | 05:22 AM
  #34
01__Excursion
If the electronic ac system has a thermister inserted into the evap coil, not sure as I have the analog system, you can move it closer to the exit of the evap coil so it senses cold temps later.
Old Jun 7, 2025 | 01:26 AM
  #35
Rainmaker1's Avatar
Rainmaker1
I’ve had nearly every component in my a/c system replaced with all OEM parts and the vent temperature varies. One time I saw it as low as 45 deg but most of the time it varies from 49-52 deg.
Max outside temps were 93 and as low as 80. I haven’t seen any consistency in vent versus outside temps.
shouldn’t the vent temp be more consistent in the 45 deg range?
what vent temps are you guys getting?
Old Jun 14, 2025 | 11:37 PM
  #36
Rainmaker1's Avatar
Rainmaker1
No feedback?
Old Jun 15, 2025 | 07:44 AM
  #37
Excurvelle's Avatar
Excurvelle
I think it depends on the ambient temperature and humidity. Mine definitely suffers in 86+ weather with high 50's output, at 100 degrees I am lucky to see 60-65, this is on the 6.0L, I haven't done a reading on the 6.8L.
Old Jun 15, 2025 | 08:25 AM
  #38
4Kids's Avatar
4Kids
I'm looking forward to your results and see if they track with mine. We have the same pair of Excursions.
If we get similar results, then I'm going to start seeing if it is the Electronic Climate Control, the thermistor location, or if there is a unique heater core thing specific to the 6.0L. I've read about people installing a ball valve on the heater loop to improve A/C performance to prevent heat from bleeding into the system.
Old Jun 15, 2025 | 01:00 PM
  #39
Excurvelle's Avatar
Excurvelle
The hot water valve should cut off all heater core flow, mine was not so I plumbed it into the recirc door.
Question: Could the rear a/c keep the front A/C from working properly? I am very suspect of that little filter, expansion valve and rear core itself, the only parts that have not been replaced.
Old Jun 15, 2025 | 02:13 PM
  #40
01__Excursion
I would think not as the TXV restricts the freon when the system is not in use to prevent freezing, and varies/regulates the freon when it is in use. A clogged strainer filter should mimic a closed TXV.
Old Jun 15, 2025 | 04:16 PM
  #41
Excurvelle's Avatar
Excurvelle
I am thinking the filter may be plugged but if I have to evac the system I am going to replace the filter, receiver drier, orifice tube and rear expansion valve. We have a trip the 4th of July and will tackle it after that. I am going to use the 6.8L and get the pressures off of it, maybe I can mimic those on the 6.0L when I recharge it.
Old Jun 15, 2025 | 04:32 PM
  #42
critteritter's Avatar
critteritter
I’ve replaced everything on my 6.0 with the automatic climate control and rear AC. Orface, rear filter, expansion valve front and rear evaporator, drier, condenser, compressor, and the temperature blend actuator. Outdoor temp probe reads accurate.
Same results as the rest of you. I get mediocre performance over 85° or so.
I’m suspecting the amount of refrigerant to be incorrect. I’m probably going to take it to a shop next week for a full diagnostic to see what’s causing the poor AC performance.
Old Jun 15, 2025 | 05:36 PM
  #43
01__Excursion
Was it evacuated (Vacuum pump) to a low micron before charging?
Old Jun 16, 2025 | 02:08 PM
  #44
Excurvelle's Avatar
Excurvelle
I had that done too, took it to the dealer, did not help.
Blue Ex
New Member Introductions
Mar 29, 2008 06:27 PM
slpre
Dec 23, 2007 06:16 PM
