Has anyone used this Crane Cam in there 300? The part number is CRN-503905 from the summit racing equipment catolog. Heres the link to the website. I just want something a little bit more than stock would this be a good cam to use?
if its the powermax cam then i have it. i swapped it into my 93 300 and it gave it a shot in the ****. i mean, it pulls so much harder through out the powerband and seems like i gained 50hp (realistically probaly 15). this is a torquer cam and will give u a better power range from idle to WOT. also, i have my timing set @ 14 degrees BTDC and it seems to be fine.
I went to the Crane site a while back - searching for the spec's on the 503905 (truck cam). The only thing I found was a cross-reference to their 503901 Powermax.
Optikal - do you still have the box/specs on the 503905? I find it a bit hard to believe that the two cams have the same spec's.
