96 f150 ac
Old Jul 8, 2024 | 06:44 PM
Cdhill's Avatar
Cdhill
3rd Gear
96 f150 ac
We put everything new on the ac system including switches but the compressor will kick on then kick right back off. It has and is holding freon. Does anyone have Any suggestions I want to check
Old Jul 8, 2024 | 08:06 PM
85e150's Avatar
85e150
Post moved.
Old Jul 9, 2024 | 10:59 AM
Junktownbill99's Avatar
Junktownbill99
Low refrigerant cycles the compressor
Old Jul 9, 2024 | 11:40 AM
Cdhill's Avatar
Cdhill
3rd Gear
it had too much refrigerant in it. We had to let some out.
Old Jul 9, 2024 | 11:49 AM
Junktownbill99
The system is designed to cut off the compressor when pressure is too low. Chances are you didn't have too much refrigerant.
What is the PSI on the low side when it's on? (fan high, Max ac, engine running) Ambient temperature?
Also did you vacuum the system before charging it?
Old Jul 9, 2024 | 02:22 PM
Hit Man X's Avatar
Hit Man X
Probably undercharged or potentially bad fan clutch.
Insufficient data to diag completely.
Old Jul 9, 2024 | 07:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You put Freon in the system? That isn’t good since a ‘96 should have R-134a as the refrigerant. The last system to use Freon (R-12) was 1993.
You added too much refrigerant? How did you manage to do that? There should be a sticker that states how many ounces to fill the system.
…or overcharged. There is a high side pressure switch on R-134a system.
Definitely do not have enough information. What are the low and high side pressure readings when static and running and at what ambient temperature?
Old Jul 9, 2024 | 07:25 PM
Hit Man X's Avatar
Hit Man X
Of course it could also be overcharged Being factory 134 truck it has tag showing 38oz plus data all over showing it.
Bad fan clutch also would cause high side switch to trip due to no air flow...
MONAVIERONJON
Jul 21, 2022 07:00 AM
Grantford
Aug 25, 2019 01:08 PM
run6.0run
Oct 20, 2013 03:43 PM
zuikoman
Sep 26, 2008 08:09 AM
Wengnutt
Mar 30, 2005 06:04 PM
