fuel injectors
Old Nov 27, 2003 | 08:49 PM
chaindragger's Avatar
chaindragger
fuel injectors
I hope someone can help. Heres my problem- I have an 89 f150 inline six. It idles and runs really rough. I have changed the plugs,wires,cap and rotor put in 2 cans of injector cleaner. Still runs terrible. When I pulled the plug wires (one at a time)lol I found when I pulled #5 nothing happened. I pulled #5 plug and found it to wet, leading me to believe possibly #5 fuel injector might be bad. If this is the problem what would be the easiest and cheapest solution to fix it? Thanks for any help.
Old Nov 28, 2003 | 12:18 AM
LxMan1's Avatar
LxMan1
By depressurizing the fuel line, there should only be a couple of bolts holding the fuel rail on, then you may replace the injector. Try puting a good plug in the #5 wire and lay in on the engine. Start it up and make sure that it is firing and that the plug wire is not bad.
Jimmy
Old Nov 28, 2003 | 08:00 AM
chaindragger
Thanks Jimmy,
I already did the plug thing, I've swapped plugs and wires to no avail. Do I need to pull the air plenum in order to get to the fuel rail? If I do it scares the HE-- out of me,Vacuum hoses,wires thing-a-jigs etc.
