Crank no start
Old Aug 25, 2024 | 11:53 AM
57for's Avatar
57for
I have finally diagnosed the problem.
Bad computer, went down and exchanged it hooked it up started it fired up and stayed running rough though.
2 cylinder were not hitting.
long story short pulled the 2 injectors out replaced everything good.
So much for sending them out to be checked and cleaned and then sent back with a report before and after that they were like new now.
Thanks for every ones input I appreciate it.
We all solved another problem check the new parts,there not always good.
Old Aug 25, 2024 | 04:44 PM
FuzzFace2's Avatar
FuzzFace2
Good to hear you got it running again.
How did you come by that the computer (ECU) was bad?
On the parts you are 100% right on that.
That is why when you have a problem DO NOT throw parts at it.
If you want to all good but do it 1 part at a time and if you dont have a change after changing the part put the old one back in place and change out the next part you bought till you got them all changed out.
You will either found the bad part or you have more than 1 part bad to cause the problem.
Most of the time we can walk you thru how to test when part is the cause so you dont fire the parts cannon at it for a fix.
Dave ----
Old Aug 25, 2024 | 05:05 PM
57for's Avatar
57for
Ecu was sending info to injectors then after 3 or 4 seconds stopped
i pulled it out and saw some leaking capacitors on the board, bingo that’s the problem.
I guess it was bad luck on the first ecu being bad.
What really made me mad was the injectors that I sent out to be redone
.and 2 of them junk.
anyway life is never simple.
57for
Aug 20, 2025 03:22 PM
57for
21
Apr 27, 2024 04:22 PM
CES69
33
Aug 12, 2023 05:04 PM
shloohoo
May 27, 2023 03:18 PM
TexasCW
Oct 6, 2022 06:58 PM
