Hi all Ive replaced nearly every component on my clutch system, most recently I did the slave cylinder. It is really failing to bleed completely, I tried bleeding it at the bleed screw multiple times for hours on end to no avail. I bought a manual vacuum pump from harbor freight to bleed at the master cylinder, but there are two holes inside the master cylinder that are both so small I can’t get the cone head bits for the vacuum kit in them. I settled using a suction cup fitting that covers the entire bottom of the master cylinder. I pumped and got good vacuum, but when I pulled it off, all I did was suck out all the fluid in the master cylinder. I’m not sure what I am doing wrong?? Is there a bleed screw I can ad to the slave cylinder as opposed to having that weird hexagon set screw instead? It’s not even a real bleeder screw. I assume not for how shallow the hole is. What am I doing wrong reverse bleeding from the master cylinder? I even sanded down and cleaned the cone ends and they’re still too big to fit in the master cylinder holes? I have a steel braided hydraulic line so I’m not sure if that makes a difference somehow
Update:
My clutch is still very bad, it doesn't full return when I let off the clutch and I struggle to put it in gear if my foot is to the floor on the clutch. Sometimes I have to pump the clutch a few times so it slips into gear. It also wont go into reverse without grinding, or if i go from first to reverse quick enough it crunches but only a little. This has sort of been an on-going issue since may and all my research says that the bubbles will work its way out of the system eventually but I don't see that happening soon. If anything my clutching appears to have gotten worse. Should I take the little rubber shoe out of my master cylinder? Would that allow bubble to escape easier or something?
The big rubber cup inside the master cylinder that you put in with the cap, it seems luck air would never be able to escape with that thing
The only broken bit on the fire wall is near the emergency break but I repaired that already
I can drive the drive but it stuggles to up shift and down shift when I use the clutch, I have better luck float shifting
I would pop that rubber thing out to make sure the master has fluid in it.
They also say to get it out and drive in over bumpy roads.
The shaking works the air up the line to the master.
Someone also said taping on the slave & line with a small hammer also helps before the road drive.
Dave ----
I often wondered would it be possible to take the slave off the side of the transmssion(if you have that external type) fish the slave and the line up into the engine bay, and hold the slave up high while bleeding it. If you opened the bleeder on the slave, this would be high ground and the air would be more persuaded to leave.
A lot of things to go wrong with this experiment. I know on my diesel, the slave came with a plastic strap to hold it retracted. Even then it was tough to get in place. Then later I took it off without the strap and I thought I would never get it back in place, the slave is very hard to retract by hand.
And then I do not know if the line would cooperate and let you fish the slave up high into the engine compartment.
But you would think if the bleeder screw was high up, then it would bleed the air out.
The rubber cup is important. If not attached to the cap when you remove it pull it out. There should be no fluid in the cup and no cracks or leaks. Once the cup is removed fill the master reservoir to the fill mark. Do not overfill. Carefully replace the rubber cup and cap. The cup should just fit in without displacing any fluid in the reservoir, taking up the air volume in the reservoir. With rubber cup and cap tightly on you should be able to pump the clutch up eventually. Air will work it's way up and out. Your braided line is not stock. I wonder if it can handle the pressure without expanding? That would reduce the throw. I always fill the slave before connecting it to the line. There could be some air in the bottom of the line but it will work it's way out. You can't have any high points that can trap air. Sloping up from the slave to the master. You can reduce the amount of air at the end of the line if the reservoir is low, less static pressure on the line and it will drip less with the cap on. After you connect the line to a filled slave, top off the master and start pumping to purge air. Pump it until it returns on its own. Then drive it. I think I posted the driving method before?
Hi all,
I bled the master cylinder and the slave cylinder a different way, more akin to how the newer models are bled. I also found a crack in the fire wall where whenever i would press the clutch, the panel connect the clutch master cylinder and brake booster flexed. I welded the panel with a few tacks to the main firewall and now its solid. However, the way I bled it this way was the way my chiltons manual told me to bled the system for newer trucks. It says to basically removew the slave cylinder from the line and the truck and stick the line into a bottle of brake fluid. I then took out the slave cylinder and submerged the inlet hole into a bowl of brake fluid. I pulled and pushed in the piston and when I would push it out, some bubbles came out. I replaced the whole system making sure no air got in, the slave cylinder being extremely hard to replace since I tried to replace it without the strap that keeps it in place. I got in the truck and had less clutch response and when I started it, I had the clutch in and it was in gear and even with the pedal down all the way it still moved. Maybe I need a new clutch? I have an srod 4 speed, what size clutch should go in it?
The size clutch is determined by what flywheel is installed. If the flywheel has been changed previously, the aftermarket flywheels can be drilled for 10 inch and 11 inch clutches. You won't know till you tear it apart.
Welding up the firewall is a temporary fix. It's just too thin to handle the flex over time. I'd get the repair bracket or fab up your own.
Removing the line from the slave and putting it in a container sounds good in theory but when you pull the line what ever drips out will be replaced by air as you remove and dip. I'd skip that step. Submerging the slave in a bucket of fluid? I'll pass on that suggestion when it's a simple matter to fill the slave in your hand.
Last month I did a roadside slave replacement with a minimal harbor fright tool kit laying on a piece of cardboard. Within 2 hours I filled the slave with fluid, attached the line, installed it, pumped it up, drove it 8 miles and had a working clutch.
Another thing worth mentioning was when I was reinstalling the slave cylinder on the fork, it was really hard to get it in place since the piston in the slave cylinder kept extending everytime I would push it in, it would extend back out again. Also the fork was not moving one bit. Is there a way I can diagnose the fork? like maybe how much torque it takes to push against it before it moves? Is this a componenet thats supposed to move easily? I have access to a bore scope that could help diagnose inside it if there is a problem internally
I recall there is a little play in the fork before it contacts the TOB. The Slave cylinder may take up that play after it's installed. I also recall the TOB should not be spinning all the time, so there should be a little movement in the pedal before the fork touches the throw out bearing. It's been a few years since I've played with a manual tranny.
The slave push rod has a spring. Some are pretty stiff. The slave comes with a restraining strap which should remain in place until the slave is installed. Book says snip the strap after installation. Some like to unhook the strap so it's reusable. The end cap of the strap is the bearing between the push rod and the fork lever and should remain on the slave. You don't need to submerge the slave in brake fluid. Simply tip the slave upward a bit with the hydraulic line port facing up and fill the slave with fluid. Tipping it back and forth a few times will burp some air. Fill and burp till it's full to the brim, then attach the line and install the slave. I slit the foil with a knife to make a pouring slot. Easy to slowly fill, burp, fill then install.
