Rear view mirror?
Old Jul 2, 2024 | 08:55 AM
The Peddler's Avatar
The Peddler
Rear view mirror?
I need a rear view mirror for my ‘73. It doesn’t have to be OEM, but I don’t want it to look out of place.
I was thinking of using this one: Amazon Link
Anyone have a better suggestion? Also, my windshield has never had one installed. Is anyone able/willing to provide a couple measurements for placement?
Old Jul 2, 2024 | 01:14 PM
FuzzFace2's Avatar
FuzzFace2
I think that one would work but I did not read the link how wide is it?
As for placement get a grease pencil, fold down the visors and place the mirror up so it clears the visors and you can see out the mirror.
May need someone to hold it up in place as you sit in the seat. Once it clears the visors and you can see out of it mark around the base of the mirror.
Now on the outside mark where the mirror was on the inside because you will need to clean the inside and the inside grease mark will be gone.
Now you can prep and glue the mirror base tab to the glass just MAKE SURE the tab is facing the right way before gluing it to the glass.
I would also not mount the mirror to the tab for a few days just to make sure it has set up good.
BTW I have a glass shop install a mirror tab and they mounted it to high and could not use the visors with out moving the mirror.
It also fell off a few days later and I just left it off as I had good outside mirrors and I pulled a trailer a lot and the car blocked the inside mirror.
Dave ----
Old Jul 2, 2024 | 01:59 PM
The Peddler
Dave ----
Thanks for the tips Dave. The mirror in the link is 10.5". I must have pitched out the original, as I can not find it. How wider were the OEM mirrors?
Old Jul 2, 2024 | 04:51 PM
scottscott's Avatar
scottscott
The mirrors in Ford trucks up thru at least 2013 are basically the same as the old trucks. As long as it is a more base model. Should be easy to find at an auto recycler for cheap.
The original mirror in my 79 F150 is 9" wide. I seem to recall that some of the more upscale trucks (Ranger XLT) got a wider mirror, but I could be wrong on that.
Mounting tab is 2" down, to the top of the tab. Centered of course.
Old Jul 2, 2024 | 04:52 PM
tbear853's Avatar
tbear853
Originally the button was maybe 3" from the top, dead center. The mirror was in my way. I removed the button and drilled it for a counter sunk screw, mounted it to a plate secured between the inner visor clips and cab interior. I mounted the mirror on that. I's never fell off, nor likely to and while the mirror is higher, it gives a great view of the roadway behind. I have since then added a shelf to the back to set my XM antenna on, but it's not here.
Old Jul 2, 2024 | 05:26 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Old Jul 2, 2024 | 08:20 PM
Viper Pilot's Avatar
Viper Pilot
I have a new in box re-pop from LMC that I’m not going to use (P/N 38-5120-F). It’s yours at no charge if you want it. I bought a newer one with backup camera. PM me.
Old Jul 2, 2024 | 08:38 PM
The Peddler
Awesome! Message sent.
Old Jul 4, 2024 | 10:03 AM
78F150_Ken's Avatar
78F150_Ken
Concur with fuzzface on placement, hold and mark where it doesn't hit the visors when fully extended down. I use painter's tap on the exterior side to mark it then use the extra strength rearview mirror glue.
As far as suggestions, I recommend a used Gentex (from Ebay) that comes with homelink (to open garage doors), compass and auto-dimming. You might pay $45, tops. I've put several of these in old cars and love them. I don't like to flip the originals up when someone is driving behind me at night and blinding me so the auto-dimming is very useful. I also like not having a garage door opener clipped to my visors. You'll need to run 12V key on, 12V BAT and a ground, but that's easy. You can splice off of the radio circuit if you have an original harness. These are a little bigger than the original, but not much.
Old Jul 4, 2024 | 11:46 AM
Viper Pilot
That’s pretty much like the one I have but it includes a backup camera that mounts to the license plate screws. The wiring is fairly easy as it just taps into the backup lights. As soon as I can get the windshield installed we’ll see how well it works. Reviews seem good.
Amazon Amazon
Old Jul 4, 2024 | 01:08 PM
jflem's Avatar
jflem
You guys are fancy. I just purchased a repop 12" mirror. The center of the tab is 4" below the seal. Does not get in my vision but I am only 5'9" so you tall folks may want it higher.
Old Jul 4, 2024 | 09:56 PM
SlikWillie's Avatar
SlikWillie
There's a build on here, somewhere, where a guy used a '64 Mercury car mirror. It looked great, IMO. Since I read that thread, I've been looking for one.
Old Jul 6, 2024 | 12:45 PM
tbear853's Avatar
tbear853
I was guessing from memory, I said about 3" down, but yeah .... 4" looks right.
CR172
2015 - 2020 F150
Jul 15, 2020 12:46 PM
Buildpro
Transit Connect
Mar 11, 2017 03:57 PM
powerstrokin007
May 25, 2007 01:00 PM
