Lost O/D
Old Jun 30, 2024 | 01:44 AM
FrankNBeans's Avatar
FrankNBeans
Lost O/D
Hello,
2006 Expedition 5.4 3 valve with 179,000 miles. Lost overdrive. Shifts fine from a stop; 1st, 2nd, 3rd then slips when it goes into O/D. Like it’s in neutral. Manually downshift to 3rd and it runs fine. Turn of O/D, it drops a gear and runs fine. No DTC codes. I’ll check fluid level in the morning. First time this happened. Any suggestions? Basically feels like I lost O/D.
A filter and ATF fluid change was on my to do list, would that help? I have a bottle of Motorcraft Friction additive for transmission/ differentials. Would that help??
mike
Thank you for those who replied. It appears I lost 3rd and Overdrive. Added some trans slip stop and the problem still exists. Some YouTube comments have similar issues and stated: “The direct drive clutch drum failed and the splines stripped out and that’s why he lost 3rd and Overdrive”.
Is it worth dropping the pan and replacing servos (and fluid, filter, pan gasket) or just take to a transmission shop and have it properly diagnoses and fixed?
mike
Just dropped the transmission pan on my 2006 Expy 4R75E trans (please correct me if that’s not my transmission). Fluid looks dark, lots of metal shavings, and the original yellow dipstick stopper is is the pan (indicating it’s never been open and serviced at 107,000 miles). I bought 3 servos, filter, and 2 gallons of Mercon V. I’m going install the new servos, filter, and fluid. But I’m probably looking at a rebuild. Anyone know of a good transmission shop in the Tacoma, WA area? thx
Old Jun 30, 2024 | 11:21 AM
alloro's Avatar
alloro
The fluid and filter change won't help, it needs to go into a transmission shop.
Old Jul 3, 2024 | 11:39 AM
Hit Man X's Avatar
Hit Man X
Doubtful you burned the band as it is 2" wide and only applied in OD and Manual 2. It probably just has a failed OD servo or its snap ring., it could have a valve body issue with whatever valve applies for the 3-4 shift. I can check whenever I get home for a full VB diagram.
Drop the valve body and take a look. Easy fix if servo, just use long screw driver to grab band's anchor and shove back into case. Wedge band with a plastic tool. Reinstall servo with aide of floor jack as the spring in there is pretty beefy.
EDIT -
I would verify the aforementioned. Then 13, 14, and 16 all move without issue.
Paula Murphy Triphan
Mar 14, 2020 03:12 PM
Krameraxe
Aug 21, 2016 08:55 AM
jadesdad
2004 - 2008 F150
Aug 14, 2015 11:45 AM
ATC Crazy
1997 - 2003 F150
Apr 21, 2006 12:21 PM
dandtnor
1983 - 2012 Ranger & B-Series
16
Dec 27, 2005 02:43 PM
