intermittent wiper trouble
Old Nov 27, 2003 | 05:08 PM
92banana's Avatar
92banana
The intermittent wipers in my 93 F150 only work intermittently
part time and not at all delay positions. Anyone have any ideas where to start. thanks. Randy
Old Nov 27, 2003 | 08:49 PM
aikigod's Avatar
aikigod
Yeah, I had the exact same problem. Try cleaning the contacts in the multifuction switch. You need to first pry the end cap off of the stalk (you can use a knife, or a very small screwdriver). You'll see a phillips screw; remove it, being careful not to lose the springs or pins underneath. The contacts are underneath the second plastic cover. I found mine to be very gummed up and dirty. After cleaning the copper contacts with some old carb cleaner I had lying around, I reassembled everything, and it's been working great for the past six months or so.
Old Nov 28, 2003 | 02:36 PM
92banana's Avatar
92banana
Thanks for the reply.
I cleaned the contacts and it seems to be working fine now. thanks. Randy
Old Nov 29, 2003 | 12:15 PM
Talyn's Avatar
Talyn
just spray potentiometer cleaner in tehre. and twist it around a lot. That will be a lot quicker.
Yes. i can't spell potentiemeter or however you spell the stupid word. But if i said POT you guys would say WTH?
