Dummy shaft
Old Jun 29, 2024 | 06:33 PM
Gary366's Avatar
Gary366
Trailering
Dummy shaft
I need some help. I’m trying to fix SROD transmission on my 1981 F150 and I need a dummy shaft part T64P-7111-A, but I can’t find one anywhere. Does anyone have one I could borrow for a bit or that they would be willing to sell me?
Old Jun 29, 2024 | 06:59 PM
FuzzFace2's Avatar
FuzzFace2
What dose this shaft do and where is it. inside the trans?
Is it used to hold bearing and gears together, the assy dropped into the trans case and the shaft pulled out?
Dave ----
Old Jun 29, 2024 | 07:49 PM
Gary366's Avatar
Gary366
Trailering
Dummy shaft
The dummy shaft is driven in to remove the shaft that holds the gear clusters in place so that they stay in place but allows the gears to be dropped to the bottom of the case for removal.
Old Jun 29, 2024 | 11:22 PM
kr98664's Avatar
kr98664
This is a tool for assembly/disassembly, right? How critical are the dimensions? Some older Jeep transmissions used a similar tool. I just used a piece of pipe that was close enough in size.
Check out this auction:
https://www.ebay.com/itm/266791178746
Even though the auction has ended, the pics are still available for now. Save the pics in case you need to fabricate a reasonable facsimile.
This spiffy chart even lists the dimensions:
If the dimensions are critical, a machine shop could easily make something for you.
Old Jun 30, 2024 | 06:28 AM
FuzzFace2's Avatar
FuzzFace2
I was thinking a wood dowel but if you need to drive out the metal shaft that may not work.
Dave ----
Old Jun 30, 2024 | 07:19 AM
kr98664's Avatar
kr98664
That would depend. If you have to wail on the dummy shaft with a hammer during assembly, you’d probably leave splinters behind.
If only an issue during disassembly, a little debris would not be a big deal if all parts either get cleaned or replaced.
IIRC, on the transmissions I’ve done, the dummy shaft is just a spacer during assembly. You push it out with the real shaft. You then drive the real shaft home the last inch or so with a brass hammer. Any hammering (and possible debris) is on the outside. I don’t know if this transmission is the same.
On a related note, use heavy grease to hold the individual rollers in place during assembly. It’s been a while, but I think you build them up on the dummy shaft and then carefully slide the whole shooting match inside the cluster gear. When you drive out the dummy shaft, the rollers stay behind inside the cluster gear.
Old Jun 30, 2024 | 07:31 AM
FuzzFace2's Avatar
FuzzFace2
I was thinking the same with the wood splinters and why I said may not work.
Dave ----
Old Jun 30, 2024 | 07:43 AM
kr98664's Avatar
kr98664
I was thinking the same…
Yeah, but I said it first. Therefore I win!!!
I think a simple engraved trophy would be appropriate. Nothing too fancy, maybe comparable to the Stanley Cup, if unsure what to get.
Or maybe you could hire a team of pilots to fly a banner over every major US city.
Old Jun 30, 2024 | 08:41 AM
FuzzFace2's Avatar
FuzzFace2
All I got is "you smell ......... nice"
Dave ----
oldcoupe42
Mar 6, 2004 07:04 PM
Darrin
Jul 1, 2003 04:59 PM
