Horn Not Working
Old Jun 29, 2024 | 05:31 PM
black33ford's Avatar
black33ford
Horn Not Working
I'm installing a new Painless harness in my '66 F100. My diagnosis has yielded that pressing the horn does not provide a ground out the 7-pin steering column connector to operate the horn relay. Either the horn switch is bad or it's not accessing a ground inside the steering column. There seems to be no ground wire into the steering column, so I assume the column is accessing ground through contact with metal body parts. Can I get to the switch by taking the steering wheel off? If so, how do you get the horn ring/button off the steering wheel?
Old Jun 29, 2024 | 06:23 PM
KO1960's Avatar
KO1960
The horn button should twist off. There are two spring loaded horn brushes that make the connection.
Old Jun 29, 2024 | 09:50 PM
black33ford
See from the pic that the button that the horn ring is supposed to connect to seems to be recessed to the point that the ring cannot touch it. Is this the way it's supposed to look? If I ground that button, the horn does honk.
Sorry this image is so big.
Old Jun 30, 2024 | 11:56 AM
black33ford
Got it figured. Pulled the brush out and it's worn down to a nub. Ordered a new one.
mcline
May 18, 2020 07:25 PM
jerryst
Mar 7, 2016 09:58 AM
dcubedus
Mar 17, 2006 08:46 PM
JStan
Oct 17, 2003 06:23 PM
