Muffler exploded
Old Jun 29, 2024 | 04:35 PM
mOROTBREATH's Avatar
mOROTBREATH
Muffler exploded
I went out and started my truck just now and after idling for 2 seconds BANG. I thought the engine blew up, but it was the muffler.
1) I do not smell the smell of a "rich running vehicle", so I don't think it runs rich.
2) I ran it this morning and it started and ran fine.
3) It doesn't look like there was anything plugging the exhaust.
Exhaust is not original, but is at least 40+ years old and probably a good bit older.
Any ideas?
Old Jun 29, 2024 | 05:02 PM
pintoplumber's Avatar
pintoplumber
I bet that was a thrill.
Old Jun 29, 2024 | 05:04 PM
abe's Avatar
abe
It could have blown up due to its age.
Put on a Smitty's or another cheaper glass pack .
Old Jun 29, 2024 | 05:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm guessing you don't need to use the choke in this weather? Still, a short run earlier in the day could have left enough vapors in there to touch off. That kind of damage takes a good amount of pressure.
Old Jun 29, 2024 | 05:31 PM
52 USCG Panel's Avatar
52 USCG Panel
That's very impressive. I had something similar happen a few years back. Coming home from a car show at night, the engine was hot as we were about an hour into a two and a half hour journey. Suddenly the electrical system failed, the lights went out, and the engine stopped running...and then BANG! It sounded like a shot as the muffler blew. I think the fuel pump kept pumping gas into the cylinders after the electrical system quite, and since there was no spark, the unburned fuel traveled to the muffler. The muffler must have been hot enough to set it off.
Your situation is different but somehow fuel got into your muffler and something set it off. I was able to weld my muffler back up and keep using it. Yours looks a little worse than mine. Good luck.
Jim
Old Jun 29, 2024 | 06:02 PM
mOROTBREATH
I did use the choke. I use the choke to start it every time no matter how hot the weather is, how hot the engine is, or how long it has sat since last ran. It's just habit and it helps start more consistently.
That's how i've driven it for 14 years.
I really really hope this was a 1-in-a-million thing and isn't going to happen regularly. I have a spare rusty muffler that will hopefully work until I buy a new one. I want the same thing: plain jane round muffler.
Old Jun 30, 2024 | 08:29 AM
Truckfarm's Avatar
Truckfarm
How old are you? Habits can change😊. Raw gas in a muffler makes a good bomb. Plus, too much gas can wash the cylinders. A warm engine does not need over rich mixtures. Give no choke while warm a try, that is the way it is meant to be.
Old Jun 30, 2024 | 12:52 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I think it was showing its displeasure with the wire muffler hanger. At least no one got hurt and the damage is limited to the muffler.
Old Jun 30, 2024 | 01:25 PM
bobj49f2's Avatar
bobj49f2
Pretty dissection showing how a ,muffler is made
Old Jul 1, 2024 | 12:14 PM
firstrider's Avatar
firstrider
Have a muffler if you are interested .
Old Jul 1, 2024 | 10:29 PM
mOROTBREATH
Ok I'll try. My issue with no-choke starts is it is generally more hesitant to start or it will fire then die.
Lol, It has one hanger from whoever installed it the first time many moons ago. One time I drove to a gathering and heard scraping, come to find out the one hanger was unbolted and I had no bolts or tools. Someone found me some bailing wire and I left it there as insurance after I fixed the mounting bolt.
I'm good, thanks Denny, I bought one off rock auto.
Old Jul 2, 2024 | 05:47 AM
KAofGA's Avatar
KAofGA
The thing about no choke starts is someone you still have to pump the throttle a couple of times, or at least I do in my 390. If your truck is sputtering and dying, you may as well. I'll defer to the old timers who drive flatheads regularly if they disagree.
Old Jul 2, 2024 | 08:19 PM
mOROTBREATH
But thats the same thing as simply pressing the gas once and pulling the choke **** out a bit and starting. lol
and that's why I do it
Old Jul 2, 2024 | 08:22 PM
KAofGA's Avatar
KAofGA
Lol. Fair enough! That 390 needs both when it is cold, so I figured they were different in their own special ways!
Old Jul 3, 2024 | 08:13 PM
spacecowboy57!'s Avatar
spacecowboy57!
3rd Gear
Smile '56 F100 Heater problems!
Howdy Denny, Happy Independence Day! I'm trying to find a stock 2-speed 12-volt heater blower motor, since mine is dragging and squealing when 12 volts are applied. Can it be lubricated, somehow? I also need defrost hoses and switch panel and cables for my '56 F100 using the stock heater box without the fresh air option. (the intake vent has been deleted on my cab) I've been told that you're the man to ask, so here I am asking! I hope you can help me out, as my truck has been apart for over 40 years, and it's like a big model kit with no instructions. Thanks in advance for any and all help that you can provide!
