What construction materials are you carrying on the front of the truck?
My guess is possibly a rack that is bracketed to the frame in the front and the materials hang considerably over the front(and the rear) squatting the truck. The real solution is a heavier duty truck choice. If a f150, get an f250, if an f250, then f350 or larger. The truck isnt going to like that weight on the front even if it is leveled correctly, the components are going to be stressed
I’ve been running these shocks for years. Both front and rear. Thought I would see if there was some others out there. Thank you for all the suggestions.
Going with the Bilstein 4600 shocks and moog
cc820 coil springs. Will I need to get an alignment after installing? Thanks for your input.
You may need an alignment, maybe not. Depends on how it is now.
One thing to note here, the cc820s are a standard load replacement, they shouldn't mess up the alignment, but you still shouldn't load down the front that much.
I understand what you’re saying about the springs. I’ll be sure not to overload them. Alignment was done 3 months ago when I purchased new tires. For some reason Amazon shipped each shock individually. Both springs and 1 shock are installed. Second shock arrives today. Thanks for the help.
4600s are a good choice.
Hard to know. If the springs were that worn out it is likely that the alignment (caster & camber) is now off.
Maybe the 822’s would have been a better choice?
Right, I had no idea I needed $1000 in work (excessive play in ball joints) until I got new tires, and the alignment check. Hard to tell without specifically looking for issues.
820s are probably fine if he keeps most of the weight in the bed.
