Starter
Old Jun 27, 2024 | 06:02 PM
Kearns1's Avatar
Kearns1
Trailering
Starter
When I start it it just makes a clinking sound like the starter is out or the cylinode I have a video but it wouldn’t let me upload it here I tried but I didn’t know if it worked
Old Jun 27, 2024 | 10:32 PM
John in OkieLand's Avatar
John in OkieLand
I upload Videos to YouTube, and then just link to that YT video,
I don't think the forum will accept video uploads.
Old Jun 28, 2024 | 07:24 AM
udsuth78's Avatar
udsuth78
Have you tried starting it in neutral or holding up on the shift lever?
Old Jun 28, 2024 | 08:27 AM
FordTruckNoob's Avatar
FordTruckNoob
Here. I hosted the video for you.
Sounds like the solenoid is not extending the gear or the starter has backed out of its mounting hole.
Old Jun 28, 2024 | 09:44 AM
Kearns1's Avatar
Kearns1
Trailering
neutral yes no start same noise holding up no
Old Jun 28, 2024 | 10:10 AM
Eman85's Avatar
Eman85
No crank diagnosis should start with testing each battery and then a good cleaning of all terminals if batteries test good.
Old Jun 28, 2024 | 10:18 AM
Kearns1's Avatar
Kearns1
Trailering
batteries are good no corrosion
Old Jun 28, 2024 | 10:32 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Have the bolts loosened up on the starter?
Old Jun 28, 2024 | 11:07 AM
bwguardian's Avatar
bwguardian
Pull the starter and look at the ring gear...sounds like there's a damaged area or the starter is loose as aforementioned...
Old Jun 28, 2024 | 12:34 PM
RacinJasonWV's Avatar
RacinJasonWV
If the bolts are tight he could try barring over the crank pulley a bit to see if there is another section of flex plate that still has good ring gear. At least it might get it started and moved to a good repair location is that’s it.
Old Jun 28, 2024 | 01:39 PM
brian42's Avatar
brian42
Veteran: Navy
Common-ish issue with starter bolts backing out. I caught mine before they backed out too far and used some blue LocTite (242?) on the bolts ever since that time and never had them back out on me again.
Old Jul 4, 2024 | 02:03 AM
Kearns1's Avatar
Kearns1
Trailering
Starter
sorry for leaving y’all guys hanging but check this video out this is what my starter looked like before I even touched it.
How could the bolts get that loose and I believe they are stripped out because I tried to tighten them back down and they just kept spinning
Old Jul 4, 2024 | 07:01 AM
RacinJasonWV
FYI there’s no video on your last post. The forum will only accept small files. Normally you’ll need to put a video up on YouTube and then share the link.
Stripped bolts doesn’t sound good. My first thought was maybe longer bolts but I doubt there’s enough meat left to hold long term. You’ll probably need to helicoil the holes. Maybe one of the other fellas will have a better idea.
Old Jul 4, 2024 | 08:40 AM
FordTruckNoob
Yup, Helicoil the holes. M10x1.5. Get the longer inserts. The standard inserts only go about 2/3 the depth of the adapter plate.
Old Jul 4, 2024 | 05:17 PM
Kearns1's Avatar
Kearns1
Trailering
Starter
Yea I was just going to get one size bigger bolt and a tap and make the whole bigger that’s what I have heard from some people
