2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
OBD port issue
Old Jun 26, 2024 | 02:44 PM
Bryan96's Avatar
Bryan96
1st Gear
OBD port issue
Hi all I am having issues with my obd port. Has power changes fuse just in case. Powers up the scanner but doesn’t read anything just states “fail” on scanner. Anyone else having a similar issue?
Old Jun 27, 2024 | 05:20 AM
techrep's Avatar
techrep
did you try another scanner ? or did you try your scanner on another vehicle port ?
Old Jun 28, 2024 | 10:22 PM
Papa Tiger's Avatar
Papa Tiger
I'm 'gonna guess here that you have a bad OBD scanner. Maybe try a Blu Tooth type with your Cell.
Old Jun 29, 2024 | 09:55 PM
Bluegrass 7's Avatar
Bluegrass 7
Look for a pushed or bent pin not connecting.
Good luck.
Old Jul 15, 2024 | 03:18 PM
jonesjacob's Avatar
jonesjacob
4wd Low
It's good that you checked the fuse and ensured power is reaching the scanner. If the scanner is powering up but showing a "fail" message, there might be a communication issue between the scanner and the vehicle's system. Have you tried using a different scanner to see if the problem persists? It could also be helpful to check if there are any error codes stored in the vehicle's system that could provide more insight into the issue. Keep troubleshooting, and hopefully, you'll get to the bottom of this OBD port mystery soon!
Old Jul 16, 2024 | 05:23 AM
techrep's Avatar
techrep
Lol... Thought I just told him this, and how can he check for stored codes if his reader don't communicate?
Old Aug 11, 2024 | 06:04 PM
3BLADZ's Avatar
3BLADZ
Does it have a LoJack tracker installed? Look for a splitter connected under the dash.
Sometimes dealers add them.
Danbarr76
2009 - 2014 F150
Jun 28, 2022 10:27 AM
vdubber
Escape & Escape Hybrid
Sep 14, 2017 09:02 PM
Icicle
May 30, 2014 02:37 PM
pmoney1983
May 12, 2012 02:07 PM
