AC Brackets
Old Jun 24, 2024 | 09:51 AM
ApparentlyIlikeFordtrucks's Avatar
AC Brackets
I have a 1986 F250 with a 300, I'm looking for AC compressor bracket.
Old Jun 24, 2024 | 12:44 PM
FuzzFace2's Avatar
FuzzFace2
You best bet is junk yard hunting.
I think 83 or 84 up to 86 is what you need,
Before 83 the York compressor was used and uses a different bracket.
87 up use 1 belt and believe is a totally different bracket.
Now vans will have the bracket also but I dont know if they used the York compressor like ours or not?
I do know the van uses a different power steering pump, a much better GM style type.
If you can get the PS pump, brackets and hoses it should bolt onto your truck and be an upgrade of the PS pump.
My 81 F100 runs the GM PS pump and the later AC compressor.
Dave ----
Old Jun 24, 2024 | 12:47 PM
Franklin2's Avatar
Franklin2
Here's a picture of the 86 setup. If you have a different than stock compressor, you will need a different setup.
Old Jun 25, 2024 | 02:33 AM
Part numbers
Franklin2,
Thanks for the picture. Do you know how to determine the prefix for the parts numbers? I've been to all kinds of junkyards in my area and 300's are rare as anything. Mostly what I found was V8sand almost all of those were the next newer body style. I spent a lot of time searching junkyards for smog and other parts, I never saw any AC brackets.
Old Jun 25, 2024 | 06:11 AM
FuzzFace2's Avatar
FuzzFace2
As I said look at the vans as that opens up more trucks.
But you need to get the PS pump, an upgrade to the Ford pump, as the AC brackets are built for the GM style pump.
I dont think the part number would help at the yards but the numbers listed are the prefix.
All the parts in the pictures start with the number listed and you then need to look up the full part number in the book.
Looks like "19(letter)(numberxxx)" - then part number IIRC
The only part I dont have on my motor is the rear bracket "19B890" I think all it dose is support the hoses as they come off the back of the compressor.
I have not had any issues in the 4+ years the system been installed.
I do have problems keeping the system charged
It is dead again and it was working 2 weeks ago. I am starting to hate this system. It is all new parts just will not keep a charge!
Dave ----
Old Jun 25, 2024 | 08:10 AM
I was hoping to google the part numbers. I've got at least one person I found on FB who's willing to sell me the brackets and a used compressor.
Use some soapy water after you charge it and check all the fittings and shrader valves.Look for oily spots, leaks usually take oil with them when they leak freon.
Old Jun 25, 2024 | 08:39 AM
Bronco638's Avatar
Bronco638
The issue with part numbers is that most folks don't know/understand the difference between Ford Part Numbers and Ford Engineering Numbers. They are not the same. And, unless you have the interchange book, it's hard to determine which one you have and how it corresponds to the other. You're better going off of the application (Year, Make, Model, Sub-Model, Engine, etc.).
With respect to the FB Marketplace listing, you'll probably be better served by pictures. The image @Franklin2 posted is pretty accurate.
Old Jun 25, 2024 | 12:47 PM
FuzzFace2's Avatar
FuzzFace2
Good to hear you might have found a set of brackets.
Dose your truck have factory AC or dealer installed AC or are you trying to add AC to the truck?
I also added dye I just have to get out to the HOT garage to check it over.
It is so cool inside I dont want to go out
Dave ----
Old Jun 25, 2024 | 01:37 PM
Franklin2's Avatar
Franklin2
I wonder if any of these are 300 sixes.
1984
A/C Compressor Bracket
Ford Truck F250
X 170503 $Call Bonanza Auto Dismantlers USA-CA(Shingle-Springs) Request_Quote 530-677-8239 / 800-559-0349 Request_Insurance_Quote
2264 1986
Ford Truck F250 125,000 A 170388 $Call Bonanza Auto Dismantlers USA-CA(Shingle-Springs) Request_Quote 530-677-8239 / 800-559-0349 Request_Insurance_Quote
2264 1985
Ford Truck F350 127,178 A 170647 $Call Bonanza Auto Dismantlers USA-CA(Shingle-Springs) Request_Quote 530-677-8239 / 800-559-0349 Request_Insurance_Quote
2264 1985
Ford Truck F150 122,770 A 170517 $Call Bonanza Auto Dismantlers USA-CA(Shingle-Springs) Request_Quote 530-677-8239 / 800-559-0349 Request_Insurance_Quote
2264 1986
Ford Truck F150 178,000 A 170694 $Call Bonanza Auto Dismantlers USA-CA(Shingle-Springs) Request_Quote 530-677-8239 / 800-559-0349 Request_Insurance_Quote
Old Jun 25, 2024 | 03:39 PM
Sooooo, I found someone on FB and he's sending me a compressor and brackets for cheap.I think his is dealer installed. Last night I made an offer on a very nice, maybe even new bracket assembly just like the picture Franklin2 posted. It looks like I'll have nice cool AC soon.
BTW, it appears to have factory AC, but the compressor, hoses and brackets are missing.
Old Jun 26, 2024 | 05:32 AM
FuzzFace2's Avatar
FuzzFace2
The problem with dealer installed AC is that the brackets for the compressor are different and where it is placed is different than what the factory had.
I was also going to say that the firewalls are different between factory AC and no AC trucks so a factory HVAC box is not a bolt on.
Non-AC trucks have only 2 large holes on the firewall where AC has 3 and some of the smaller holes are in different places too.
Also note the dashes are different between the 2 trucks as is the HVAC controls.
Dave ----
gbakman
18
Jul 27, 2017 06:38 PM
maverick600
WTB - Parts & other
Dec 10, 2013 03:56 PM
oxbass78
Apr 11, 2007 12:31 PM
