Hello, have a 1995 e350 with 460, my cc servo module locked up, # f7uz-9c735-aa, did a little research on this and found some people using ones from different models and yrs, I seen 92-97 bronco, f series, explorer are close to my yr, if anyone can tell me what yrs and models would work on my van, I'm believing if the middle numbers [9c735] are the same it should have the same wire diagram and work, and the front numbers are for model and bracket difference, and at what yr did they go to wire instead of cable that would work? the newer the vehicle the better being that old already, I seen a new one for a 1999-2003 escort on ebay maybe that one would work? any help would be appreciated, thanks
The cables break and fail as often as the servos do
Check the cable
I think just about any 95-99 actuator should work
You might have to change the bracket and or the cable to make it work
I can expand my input but hopefully that will help answer your larger questions. In short to my knowledge there is not a list or chart of known plug-n-play VSC servo swaps I've ever seen..
Manicmechanic007, cable is ok just servo locked up, from what I had researched 95-99 like you say will work and will have different brackets and cables, thanks for your info, appreciated
JWA, seen and watched that a couple times, just wanting to get a little better input, it looks like a lot of yrs. and models will work just have to use my bracket and cable, thanks and appreciate your time
